I want to reboot my system for antivirus update process, but i cant able to reboot. so please tell me the procedure.
  • Brad Brown Oct 06, 2010
    What happens when you try?
  • Hardie Oct 06, 2010
    When you try to turn on and log into pc what message or reaction is preventin reboot
  • 7,733 Answers
Sounds that your PC is dead.In order to try TRY! You will need BOOT DISK FILES and fallow some steps ------->link.
Posted on Oct 06, 2010
When i am about to update my anti virus i can update, it asks me to reboot my computer
A lot of antivirus software will regularly push out software updates. These typically will require and tell they need a reboot to finish the update. Also if you leave your computer on and on auto update it may of installed a update and is pending a reboot. This would then always ask you to reboot if you mash the update button.
If this doesn't answer your question comment back with the Antivirus and version (This is under the "About" or "Help"
Aug 20, 2011 | Acer Aspire One Netbook 8.9" Notebook
How can i remove virus
Removing viruses, though technical, is yet a very simple process if all the required steps are properly followed.
The basic steps are:
  • Buy or download a reliable antivirus software
  • Install the antivirus software
  • Update antivirus software with the latest virus definitions
  • Perform a complete system scan
Install an Antivirus Program in the System What is Antivirus program? An antivirus is a program that searches for, identifies and removes potential viruses existing in the computer system.
Antivirus software: Some of the most commonly and reliable antivirus programs available in the market are -
  • Symantec Norton antivirus
  • AVG antivirus
  • McAfee Scan
  • Microsoft Antivirus
The antivirus software should be updated regularly to retain its effectiveness.
Before installing the antivirus, close all open applications and terminate any suspicious processes using Task Manager. Sometimes, you may need to boot into safe mode or safe mode with command prompt to delete suspicious programs and references to them in the Windows Registry (run regedit from the command prompt to open the registry editor).
Search engines are excellent tools to find out whether a certain process is harmful or not. You can also get steps on how to remove a specific virus manually.
Removing the virus beforehand might be necessary, as some viruses will not allow an antivirus to operate. However, if you are not successful, you may still continue with the installation.
Scan the System to Identify and Locate the Virus Usually, the antivirus will run automatically when the system reboots after the installation. Therefore, it might identify the virus automatically. Moreover, you may want to run a quick system scan to locate the virus.
Troubleshooting the Virus Infected Areas After the antivirus identifies the infected areas, the next step is to rectify those areas.
Methods of Eliminating Viruses
Generally, the antivirus adopts one of two methods to eliminate the virus:
  • Removing the virus - When the virus can be easily identified and can be removed without affecting other files, then the antivirus removes it from the host place.
  • Quarantine - his is done when the virus cannot be easily identified removed from the file and the removal of virus means the removal of the complete file. In this method, although the virus is not eliminated, it is rendered inactive by moving the file into "quarantine" and renaming it.
Perform a Full System Scan Even after the virus is removed from the system, the next step is to scan the whole system to ensure that no infected files remain.
Aug 17, 2011 | Computers & Internet
I cant uninstall webroot antivirus from my computer
**Note
Make sure Webroot AntiVirus is not running on your computer.(ie. Exit the program). The uninstall application will not complete successfully if the application's files are in use.
From "Control Panel" -> Use Add/Remove to remove the program
Reboot your PC and the process is completed.
Hope it helps.
Oct 30, 2010 | Computers & Internet
Ended a process and cant login, HELP PLEASE
Try to boot your system in safe mode by pressing F8. Try to uninstall anti virus. Press Start>Run>Regedit> Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Delete all values of Norton Antivirus and reboot your system. Hope this will work, otherwise new windows installation will resolve this issue.
Regards;
Hassan
Jul 22, 2009 | HP Compaq Presario CQ60Z Notebook
Windows failed to install code error 80070020
good morning! Probably, the process cannot access the file because it is being used by another process". Please try to turn off your antivirus scan then run the update. best regards
May 05, 2009 | Computers & Internet
Best antivirus
Hi! The best antivirus that won't slow down your computer is NOD32 2.7. You can download it in torrents sites. Also free up your startup memory using HIJACKTHIS I'm sure this make your computer clean from viruses. GOOD LUCK
thanks.
Mar 15, 2009 | Symantec Norton AntiVirus 2008: Windows
Antivirus blocked some of the sites i navigate
'Antivirus 360' is malware -- in effect a virus in itself.
If you can, go to a website named http://malwarebytes.org and download a trial copy of the MalwareBytes Anti Malware.
Install it, let it do it's update, and perform a full scan. When it is done, it will tell you to click to view results, then click to remove all items found.
It will prompt you to reboot the PC at that time. Let it reboot the PC. Then download and install a decent antivirus like Avast or AVG.
Mar 01, 2009 | HP Mini 1000 Netbook
Virus...need to reboot
hi.. shut down ur system. re start again. hen ur computer restarts keep pressing F1 key. it will auotomatically guide u to the re boot process... the F1 key is also called as boot menu key..
pls rate me
Jan 21, 2009 | Averatec 1000 Notebook
Commit and reboot
Do you have an anti spyware or up to date antivirus?
You should try dowloading Spyhunter or update your antivirus and scan your computer.
Nov 16, 2008 | Computers & Internet
Subscription renewal and upgrade
reboot and restart a few times and then check for updates
Oct 04, 2007 | Symantec Norton AntiVirus 2004 - (Open...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
