Question about Daewoo Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
My daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Posted on Nov 29, 2010
  • Thomas Smouse Feb 05, 2011
    I opened the machine up at the back. Took the hoses off and cleaned out clogged soap in the pump and Hoses. Refitted everything again. Ran the drum half with water - Added a few packet of Chlorine detergent disinfectant(available at supermarket" to clear slimy build up - Drained the water out---no LE error code after that.
Same problem and it sows LE.
In my case it was the door it was not closed properly now it works perfectly.
Posted on Jun 19, 2018
    Problem Solver:
Check the limit switch of the top open door and repair or adjust the tension of the spring.In case if it is rusted replace with new.
Posted on Feb 25, 2011
SOURCE:
My daewoo washin machine shows error code OE & it wont work actually whats the problem ? tq
Error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. Remove the suspected hoses and clean out. Replace and your good to go.
Nov 21, 2016 | Daewoo Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
My Daewoo DWF 806 MP doesnt dry/spin after washing and rinsing and shows LE error. When drying starts some sound comes and then LE error apperas
my Daedwoo DWF-806 MP machine when i swith on shows figure 49 and not figure 0, and it also making noise like Buzz in between when the machine is ON. Can anybody help me to resolve this defect
thanks
Nov 01, 2013 | Daewoo Washing Machines
Error message " LE "
Click the link below to troubleshoot the LE error on your daewoo washing machine:--- http://technoanswers.blogspot.com/2011/06/le-error-on-daewoo-washing-machine.html ----------- This should help.Thanks.Helpmech.
Jun 01, 2011 | Daewoo Washing Machines
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Apr 20, 2011 | Washing Machines
What does the LE code mean on my washine machine and how do I fix it?
Welcome to FixYa.
I have a suspicion of what may be at fault, but the easiest way to explain the problem and solution for the LG washer "LE" error is to direct you to my repair tip page.
Click on the link here and you should find the info you need to diagnose and ultimately repair your washer.
http://www.fixya.com/support/r8488460-lg_washer_le_error
Hope that helps resolve your troubles. good luck.
Regards,
Macmarkus :)
Apr 08, 2011 | LG Washing Machines
What is LE error for Washing Machine Daewoo DWF 772W model? how to solve it?
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Jun 16, 2009 | Washing Machines
Cl is showing on display and machine wont work
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Feb 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
4,287 people viewed this question
Top Daewoo Washing Machines Experts
Marvin
Marvin
Fahr Quad
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
