Question about Toshiba Satellite A105 Notebook
Laptop won't start
I installed itunes the other day and about three-quarters of the way through the installation, the program froze. I then cancelled it and it said that the installation was successful. i thought this was weird considering I just cancelled it.
I left the computer on that night and the next morning, the screen was black and there were three crosses on it! It would not turn on completely after that. Every time I try to turn it on, it asks me whether I want to start it in safe mode, safe mode with networking, safe mode with command prompt, last known good config., or to start windows normally. I've tried each and every one of these but NONE of these options work!
I unfortunately do not have the recovery cds however I got a copy of the windows xp professional edition. I tried using the CD to repair and to reformat (once all repair attempts failed). Both times, I would get a blue screen on the bottom of which said, "Examining 11471 MB Disk 0 at Id 0 on bus 0 on atapi." It would just stay there and not change no matter how long left on.
PLEASE help me!!
  • monikan May 28, 2008
    Thanks! you both were really helpful! I just bought a new hard drive from best buy and geek squad is installing it (i was paranoid about ruining something)
    Now can one of you tell me if it's easy to install windows xp on there? I purchased a bare hard drive so I assume I have to format it from scratch? I have the windows xp prof. cd too.
    Please advise.
    Thanks again!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Hi there, monikan. For some reason, the response I had typed has disappeared, so I will attempt to recreate that for you. There are numerous different "submodels" of the Toshiba A105, and it would be helpful to know the exact model. It is also not apparent what OS you utilized before the big crash. It appears likely that was XP, as you attempted to repair/reformat with an XP disk - ?
The best solution for this will likely involve contacting customer support (details at http://www.csd.toshiba.com/cgi-bin/tais/su/su_navShell.jsp?cf=su_contact.html&BV_SessionID=@@@@1718358070.1211987230@@@@&BV_EngineID=cccdadeeeljjlffcgfkceghdgngdgmm.0)
There is a BIOS update available for the A105 at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_supportNews.jsp?moid=1209144&rpn=PSAA2U&ct=SN&hideNav=true&sn_mod=1209144&sn_rpn=PSAA2U&sn_mpn=&BV_SessionID=@@@@1718358070.1211987230@@@@&BV_EngineID=cccdadeeeljjlffcgfkceghdgngdgmm.0; however, this will not do much good until the PC is operational again.
Recovering the machine from manufacturer recovery disks is the best thing to do, as OEM software is quite customized, and you will not get the same content even if you successfully loaded from the extra disk you have. Getting recovery disks directly from Toshiba (either physical or downloaded) would be better and more productive.
Additionally, Toshiba recalled battery packs relative to this model (see http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1788033&moid=1209144&rpn=PSAA2U&BV_SessionID=@@@@1718358070.1211987230@@@@&BV_EngineID=cccdadeeeljjlffcgfkceghdgngdgmm.0&ct=SB&all_docs=false)
so it is possible, if you had the battery pack installed and were on AC power, that this caused internal damage to your hardware. Other similar issues are listed at http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1209144&rpn=PSAA2U&ct=SB&BV_SessionID=@@@@1718358070.1211987230@@@@&BV_EngineID=cccdadeeeljjlffcgfkceghdgngdgmm.0
Again, it appears most likely that there is a hardware issue involved, and I would not recommend installing a retail version of XP versus the Toshiba recovery software. Contacting support and following their instruction is the most likely avenue to total success.
Please post back if you need further help; otherwise, thanks for rating FixYa!
Posted on May 28, 2008
  • Cheryl Whalen May 28, 2008
    If the geek squad is putting the drive in, you might see if they will put on the XP for you without charging extra - and I think it is important to try to get whatever you can salvaged from your old drive (setting it up as a second, even externally) might help. The only way you will get the Toshiba utilities back is to put your OS back in place from one of their CDs or recovery processes.
    Good luck - it should not be too hard, but if you haven't done it before and you are "starting from scratch", I would suggest asking if they would do it for you. Thanks so much for your consideration, and don't forget to let us know if you need more help, and post a FixYa rating when you have gotten the help you need!
  • Cheryl Whalen May 31, 2008
    **IMPORTANT**
    Hi there, monikan. I came across this issue relative to battery issues on the Toshiba A105 and thought of you - wanted to make sure you are aware of it. I do not know if this impacted your situation, but if the battery was one of the bad ones, it could very well be the root cause. If so, it could cause the same thing to happen with your new drive! (Or it could be a lot worse...)
    Basically, it was discovered that many batteries in the Toshiba models cited were defective and have created major issues - up to and including catching on fire! So, I wanted to make sure you were aware, and could check your battery to be certain that you are not at risk. If your battery is one of those indicated as defective, they will replace it free - and they are also very definite about not using the machine on AC with the battery installed... Please take a look at the link --
    http://www.csd.toshiba.com/cgi-bin/tais/...@@@@0089026791.1212258658@@@@&BV_EngineID=ccccadeefdghjdgcgfkceghdgngdgmn.0&ignore_sn=true
    Again, thank you for using and rating FixYa!
  • 55 Answers
It is possible that your hard drive just crashed during itunes installation process. You need to try another HD. It is possible that you can retrieve your data by connecting your defective drive as a secondary to your new one.
Good luck!!!
I have downloaded itunes to my computer but it won't open it. It is a pc laptop toshiba satellite A665D with windows 7 64 bit Why?
iTunes will install in Program Files (x86) even the 64 bit version. There are also iTunes files in Program Files as well. This is normal. It appears that the 64 bit version is really a hybrid of both 32 and 64 bit, the drivers mainly being 64 bit. Having itunes.exe 32* in the Task manager is normal
A lot of people are having problems with itunes 9.1. You can get 9.03 at this site. It ran flawlessly for me.
http://www.oldapps.com/itunes.php?old_itunes=54
hope this helps
Jul 01, 2012 | Toshiba Computers & Internet
Problem is with iTunes
hi try this: The intention is to remove all iTunes and Quicktime software references. The following steps remove the software traces and worked on my machine. 1. Using add/remove programs uninstall Quicktime (click on Start ?> Settings ?> Control Panel ?> Add/Remove Programs) 2. Using add/remove programs uninstall iTunes 3. Right click on My Computer, use Search and remove all programs named Quicktime 4. Right click on My Computer, use Search and remove all programs named iTunes (except your iTunes download, so you won?t have to sit through another long download session). 5. Left click on Start, click Run, type ?regedit?, go to HKEY_LOCAL_MACHINE, click on SOFTWARE, and remove the Apple Programs folder (you may want to check in case you have other Apple applications, but all I had were iTunes and Quicktime in my Apple folder). Steps 1 through 5 should remove all traces of the software and now you can install iTunes. make sure you install all the latest updates from apple hope this will work for you :)
Aug 18, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Itunes will not load, and there is a blue and orange icon over the itunes icon
You might have some viruses and malware...
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 29, 2012 | Toshiba Computers>Laptops Satellite A10 PC...
I am trying to download itunes onto my laptop but it wont let me download more than 76%
you sure your problem is the 'download' part?? or is it the installation part??
if it's the download part I would suggest for you to attempt to download the installation file in another computer, put it on the thumb drive and bring it over to the laptop where you want to install the itunes.
if you have problems installing itunes you probably may want to uninstall
the following programs and in the following order
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
if you can't uninstall them with 'add and remove programs', I would suggest to use this windows uninstaller and clean up utility
only once you have uninstalled all the programs above, run the itunes installer and all the programs updated will be installed one at a time.
hope this helps
Dec 26, 2009 | Apple Computers & Internet
My Macbook froze and now won't start up
You need to perform "Archive & Install" of Mac OS.
Oct 05, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I keep getting an error message when trying to install iTunes and Quick Time: iTunes.exe-Unable to locate component. This application has failed to start because QTFC.dll was not found. Re-installing the...
Uninstall your older version or any version of I tunes. Do a search for itunes and if you find more, remove them, Try it with the uninstall program utility first. If you have problems uninstalling it, maybe it tells you that you don't have permission( this has happened to me with other programs), then look for a program on the internet called "revo uninstaller". This is a great program for pesky programs that don't or can't be deleted. This "will" take em out. then, just re-install the program.
Sep 14, 2009 | Compaq Presario Notebook
Cant install os
Use a program to write zeros to the drive, and then install your O/S. The manufacturer of your HDD provides the software to writes zeros to your drive
May 22, 2009 | Acer Aspire 6930-6082 Notebook PC
Blue screen after installing itunes, what is the solution?
Boot into safe mode ( restart computer on press F8 ) uninstall itunes ( start-control panel-add remove programs- select itunes from the list-click uninstall ) than restart your computer and install an earlier version of itunes.
Jan 02, 2009 | Maxdata Pro 650T Notebook
Songs won't download from itunes
I want to trans fer songs I bought from itunes to my ipod nano, How do I do this?
Sep 09, 2007 | Audio Players & Recorders
Toshiba Satellite A105 Notebook Logo
160 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
