Question about Kenmore 24032\24036 Top Load Washer
I have overloaded the washing machine and now it is off balance and i need to know how to fix it
  • 5,911 Answers
Kenmore top loaders are equipped with an auto-leveling system on the back two feet of the washer. Typically, what happens when the washer becomes off-balance it's a simple matter of the auto-leveler needing to be readjusted. This is a very simple process that requires no special tools. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The rear auto-leveler should be periodically checked from time to time to ensure the washer maintains level. Any excessive vibration may cause the rear of the washer to become mal-adjusted. This is normal. Once the rear feet are properly leveled, make sure the front feet are adjusted so that the washer is level front-to-back and side-to-side. Use a level across the top of the washer cabinet (NOT the lid! The lid on most washers is slightly bowed.) to check.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Oct 06, 2010
What does error code dc mean?
DC error code means: "Unbalanced load". It can occur if the washer:
1. is overloaded (too many clothes inserted),
2. can't balance the load within a few balance cycles,
3. has a damaged balance sensor,
4. isn't regulated properly (vibrates abnormally).
IMHO you just overloaded the washer :)
Jan 19, 2015 | Samsung Washing Machines
When washing towels the load starts banging...not overloaded and repair service can't find the issue.
sounds like a broken shock,or balance spring!! possibly loose concrete weight on tub
Mar 15, 2013 | GE WSXH208A Front Load Washer
Why does washing machine drum bounce around?
i had same problem but i was terrible at balancing loads......also being a male i tend to overload and this also did not help.....under normal loads the shocks get a big work out going in alternating directions and with full loads......if it bounes on spin it is poor balancing,if it bounces and bangs while washing i would think shocks or overloaded
Mar 03, 2013 | Hoover Washing Machines
Aquasmart machine constantly goes out of balance. And yes, I place each load very carefully and do not overload. For example, two sheets and two pillow cases, carefully placed in a circle, against the...
mine does the same...i think it is loose bands holding the agitator in place, i am looking to see what the correct name is and where i can get it fixed.
Oct 19, 2009 | Fisher and Paykel Washing Machines
Unbalanced Load Problem
you can easily inspect where the water is comming from
carefullyinspect tghe door boot
the gey thing between the door and the washer tumbler, inspect very carefully, this has a habit of ripping when the machine goes out of balance viloently
Oct 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore washer flashing f71
These machines are very touchy and go out of balance easily. You may find success by unplugging the machine for 10 seconds and plugging it back in. Also consider releveling the machine. If you may have overloaded it, avoid that in the future. hope this helps!
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Sounds like it is out of balance. really noisy.
If overloaded or heavy items being washed it will spin out of balance.Try a lighter load to make sure its not just a one off fault. If no good its probably the drum bearings unfortunately.(needs engineer call out).
Jun 02, 2008 | Frigidaire Washing Machines
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Apr 15, 2008 | LG WM-2277HW Front Load Washer
Out of balance
Get a repair manual from http://www.repairclinic.com/
They have everythng for it. Also I replace the same part you are needing to replace. It is a black gromet that wears out over time not your fault just a common problem. If need any help let me know.
Thank you for your time
Feb 10, 2008 | Whirlpool LTG5243D Top Load Stacked Washer...
NOISEY
All washing machines need to be balanced before using , the
feet at the bottom of washer can be screwed in or screwed out to balance machine . it may take a few tries .
Also .. overloading washer will unbalance machine
Dec 14, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
83 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
