Question about RCA Televison & Video
I have a nearly new L32HD350 flat screen, and on several occasions it has done this. It will start, and a please wait message will briefly appear in the lower left hand corner, and you may see the picture for one second or so, and then the screen goes black. Still has sound, but no picture. Sometimes you can turn it off and back on and it will solve the problem, but sometimes you can try it 100 times with no result. My TV has been off since this afternoon, and to say the least I'm getting a bit steamed under the collar at RCA right now. Got any ideas??
  • Frank Fulton
    Frank Fulton Oct 06, 2010
    How is the TV connected? HDMI?, Component?, AV? Is signal being passed thru an AV receiver? What source is the signal from, DSS,Cable, FIOS, etc? If you can list the makes and models of the products used I can help you decipher the problem. Post a reply and I will get back to you ASAP.
MikeNJ1964
  • 398 Answers
SOURCE: Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Posted on Sep 30, 2007
  • 29 Answers
SOURCE: Sony kv35s66: No picture, just sound and red blinking
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Posted on Feb 02, 2008
  • 135 Answers
SOURCE: 36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Posted on Jul 02, 2008
  • 4234 Answers
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Posted on Sep 08, 2008
  • 3 Answers
SOURCE: toshiba 32df46 power on message "please wait"
Unfortunately the digital board is usually the cause. Part Number 72783389. Vey expensive part!
Posted on Nov 17, 2008
Radio not working golf gti mark 4
If factory installed put on radio.The safe sign will appear.There should be a 4 digit code for the radio.Punchin the code using numbers 1-4.Press repeatedly from number 1 till for the fist digit number 2 for the second digit etc.when you have punched the code in the safe sign will appear.Briefly press loud /expert then wait a few seconds your radiio should then display .Look for your favourite channels .If you punch in the code wrong there is a waiting period.First attempt wait 21 seconds ,second attempt1.5 minutes 3rd attempt5.5 minutes...4th attempt22 mins.5th attempt1.5 hrs. If this fails ,disconnect battery and start again
Aug 11, 2014 | 2000 Volkswagen Golf
Why my screen says please wait then goes black
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 05, 2014 | Dynex DX-LCD32-09 LCD TV
Digital lifestyles model fa2b 32570
Could be a couple of things.
The good news is that the LCD panel is working, albeit briefly.
It definitely sounds like it's repairable, though.
Dec 03, 2013 | Televison & Video
Restore software for ipod 16GB touch
i would be checking the usb lead before doing anything or even replacing it with a new one make sure iis securely connected
the cable near the iTunes symbol represents a problem with the cable
and the cd will not not be able to activate without a connection
Connect one end of the USB sync cable to one of your computer's unused USB ports, and connect the other end to the bottom of the iPhone or iPod Touch.
If iTunes does not start on its own, run it using the desktop or Start menu shortcut.
When iTunes starts, you should see an icon for the iPhone or iPod Touch on the left side of the window.
Click "Summary" in the right pane of the window if it is not already active.
Click the "Restore" button to begin the device restoration process.
ITunes displays a message asking if you want to save the contents of the device to your computer before restoring it.
If you have not backed up the device already, click the "Back Up" button.
If you have already done this, click "Don't Back Up."
Click "Restore." ITunes clears the data from your iPhone or iPod Touch and reinstalls the device's original firmware.
The screen of your iPhone or iPod Touch may shut off while iTunes works.
Do not remove the USB sync cable.
When iTunes is done restoring the device, it displays a message letting you know that the device is about to restart.
Click "OK" to restart the device. If you are restoring an iPhone or iPod touch, wait for the "iPhone / iPod touch is activated" message to appear on the screen of the device before you disconnect it from the computer.
You may now restore your backup of the device or remove it from the computer.
hope this helps
Sep 15, 2012 | Apple iPod touch
My hp officejet ignore printing after replacing of cayne colour cartridge.
I hope Magenta cartridge is not refilled one right? :#Remove all cartridges and print heads, disconnect power & USB cable, switch off wait for couple of minutes.. give power switch on the machine wait do as per the message appears on display.. once installed cartridges and printer heads wait for the ready mode:.. once ready mode appears attach USB cable then print and see..# check with old and new cartridge see the difference of message.. if both messages are same it might be problem with ISS(Ink supply station) faulty, try it get back to us..for further remedies.
Feb 03, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
www.lumaco.co.uk
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
Toshiba 32df46 power on message "please wait"
May 17, 2008 | Toshiba 32DF46 32" TV
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Tom Tom ONE Version 3
Have you tried resetting the unit? Does it do the same thing after being reset?
Nov 25, 2007 | Tomtom GO 910 GPS Receiver
Televison & Video Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
