Question about Sharp EL-1611P Calculator
How can I get this calculator to not print[-- I just want to use without paper?
Please email me back at gbarillari@lowenstein.com
  • tedens99 Jul 24, 2008
    I would like to turn off the print function of this calculator. It's very noisy when it prints. Thanks
P/NP means Print or no print. I know fairly complicated. Hit the 2nd button then NP. This key is also known as the M+ button. Hint lay off the grass.
Posted on Aug 28, 2008
How to install paper
Without a manual, look at the picture of the calculator. Mount the paper, with the feed coming forward and over the top of the calculator. Insert the paper (recommend cutting it flush) into the feed slot in the back. Then use the paper advance key to advance the paper through the rollers. Unfortunately the manual is not available from the Staples website. Good Luck,
Mar 02, 2015 | Staples SPL-P100 Printing Calculator
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2┬╝-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
Forgot how to load paper
Hello.
From FixYa Support:
While looking at the front of the P23-DH printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then, cut the paper on the roll straight across. Then, feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed through and you are ready to go.
Hopes this helps.
Mar 14, 2010 | Canon P23-DH Calculator
How do I feed the paper through to start printing
Put paper on paper arm with end of paper hanging down from the back. Cut the end of the paper at a diagonal. Insert paper into **** on back of calculator. Use feed button to feed the paper into the calculator.
Hope this helps.
Oct 28, 2009 | Canon P23-DHV Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Printing Calculator Double Spacing
Our customer care team is available Monday - Friday, 8AM - 5PM (EST) at (267) 293-6276. Your call is always answered by a live person, never a recording.
I can't find the answer to my question on monroe-systems.com. Is there another way to get the help I need? Yes, you may call our customer service team Monday - Friday, 8AM - 5PM (EST) at (267) 293-6276, or email csr@monroe-systems.com https://monroe-systems.com/customer-care-feedback
Monroe Classic User Manual Page 29
Jan 28, 2018 | Office Equipment & Supplies
Sharp EL-2196BL
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Loading paper
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Aug 15, 2007 | Canon P23-DH Calculator
Sharp EL-1611P Calculator Logo
414 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
