I need the code and the steps on how to use a comcast remote instead of the reg. remote
    President:
  • 1,114 Answers
If you go to:
http://sitesearch.comcast.com/?cat=ccentral&con=net&q=remote+programming+codes
Pick your remote, and you can view the directions online. Hope this helps
Posted on Oct 06, 2010
Cant get my comcast remote to work with my LG 42
Every brand has several different codes for a single brand as different codes were designed for a brand that uses several different codes.
The Comcast remote if working only has about 50 possible codes built into it----it may just NOT have the one you need.
May 22, 2012 | LG 32LD350 32 in. LCD TV
What is the remote code? I can't find the correct code to program my comcast cable box remote.
try this link , it might be helpful . there is a list of remotes , find your specific remote and click view manual . when viewing manual it will give you step-by-step and all codes for your TV .
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Jan 28, 2011 | RCA F31672ET TV
Need code for comcast remote for phillips/magnavox tv
Hello
Magnavox TV codes with Comcast universal remote control are:-
11866, 10054, 10030, 10706, 11990, 11963, 11913, 11904, 11525, 11365, 11198, 10802, 10230, 10187, 10186, 10179, 10096, 10036, 10028, 10024, 10020
Philips TV codes with Comcast Universal remote control are:-
10054, 10037, 10690, 11483
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code
OK.
Jan 02, 2011 | Philips Magnavox 27MS343S 27" TV
I need to program my cable box
The real problem with the Comcast remote is that there is no other brand, it's not like a Sony remote that's relabeled or anything. Fortunately, Google helps again, and it turns out Comcast has a page online about programming the Comcast remote control.
comcast_remote.jpgComcast 3-in-1 remote control To program the remote to work with your Sony TV, you need to take the following steps:
  1. Find the code or codes for your TV from Comcast's list [PDF]
  2. Turn your TV on
  3. On the remote, press and release the TV key on the very top of the remote.
  4. Press and hold the Setup key, until the "TV" key flashes twice, then release the "Setup" key.
  5. Using the number pad, enter in the first 4-digit code found next to your television brand on the chart. If you do this correctly the "TV" key will flash twice. Now it's programmed!
  6. Now point the remote at your TV and press the Power key. If the TV turns off, you're golden. If not, try again with the next code on the list.
Jun 01, 2010 | Symphonic SC3919 Combo
Rca l40fhd41 comcast code we can't find the code for the comcast remote
look at your remote from the comcast cable remote. if you use the comcast remote instead you will have better luck. but if you want to use the tv remote control for the cable box then look at what kind is your cable box? is it Jensen, Gerrade etc. this is what you need not comcast code. the name of the box is your name code you are looking for.
Feb 18, 2010 | Televison & Video
I HAVE A NEW BLC320EM98 TV AND NEED TO PROGRAM TV REMOTE TO WORK ON "COMCAST CABLE". None of factory codes woek. What does?
In your packet there should be a set up sheet for the remote when you try to set it up follow the search guide for the remote to search and find the comcast box. Depending on how the search works on that remote it may take some time and you may find more than one setting that will work. Then you have to choose the best one that operates the comcast box the best. Good luck and be patient.
Oct 14, 2009 | Televison & Video
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Tv code
Good Day, weilly101;
Look into your COMCAST booklet or call COMCAST, not TV problem. Good Luck, big IRISH.
Aug 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
