Question about GE 21.9 Cu. Ft. Side-by-Side Refrigerator - Bisque-on-Bisque
Relay on main control board clicking several times before unit starts. Each time the condenser fan turns slightly. Is this due to a bad relay or is it more likely an intermittent start signal from the solid state circuitry. Relay appears to be soldered in place. Any suggestions other than replacing the entire board (cost about $135). Initial problem of no cooling was frozen evap coils. Heater appears bad. Once defrosted the unit functions normally except for the repeated relay clicks before finally starting. I will replace the heater but the relay problem still has me puzzled. GE model GSS22JERE BB
farfield
  • 462 Answers
SOURCE: Defrost Heater or Main Control Board, Which one is at fault?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To answer your question I know of no reason the electronic type of board would cause the heater to go out unless the defrost thermostat (or sensor) and board stuck in the defrost possession and did not stop the heater. Any time you replace the board and have had a defrost problem a check of the heater will either confirm or eliminate it but the defrost sensor should be replaced if the board is being blamed for non defrost. I cant rule out 100% that a bad board will not cause a heater problem but the high 99% range is most likely. If you have a volt ohm meter and can find the heater circuit on your board and the freezer has been running down to correct temp you can check the defrost circuit by ohming it out. Lower resistance of 10 to 60 ohms is common. Anything higher will require ohming the heater out directly and the defrost thermostat will be open if the temperature is above the stats range.
Common to all self defrosting refrigerators / freezers is the need to move air around to pickup heat inside the compartment. Common to all frost free refrigeration to maintain this feature are 3 items:
1 and initiator (defrost timer or circuit board),
2 A heat source for defrost (Usually an electric heat element but can be other types of heat sources)
3 A safety limit to stop the heat source, leaving it warm enough to defrost and keep the heat contained where it will not affect the compartment advisedly. In a standard type defrost (non - electronic) it is called a thermostat. In an electronic board defrost it is called a sensor.
The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under Neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise till it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into defrost or test mode.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus won’t let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician..
Posted on Apr 17, 2009
Sea Breeze
  • 4655 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
  • 1218 Answers
SOURCE: condensor fan motor starts, evap motor tries to
1. GE is replacing many defective boards free of charge. Check with them to see if you are qualified.
2.The start relay should be closed when refrigerator is de-energized.
3. Still a possible bad compressor or compressor start components. Test performed by service tech on compressor is usually done with a starting test cord. Would answer many questions quickly.
Posted on Oct 30, 2009
Testimonial: "Thank you jackfrost555. My start relay is open when de-energized. Start and run ohms do not indicate an open or shorted winding(S)."
aasc
  • 1606 Answers
SOURCE: GE GSH22KGM Frig not defrosting again
I would suggest replacing the # 4 thermistor , which is a 1 " long white piece with 2 white wires attached , clipped to the top of the coils . This thermistor , tells the main control board , the temperature of the coils and the board decides what to do next , such as defrost , end defrost cycle . Also , replace the defrost thermostat , the 1 inch cylinder with 2 wires going to it , which is also clipped onto the coils . This thermostat , cuts the heater off when it reaches a certain temperature , to keep the food from defrosting . It may also help , to replace the # 5 thermistor , which is below the coils , slid into a housing , with 2 white wires going to it also . This thermistor , tells the board , the actual freezer temp , so the compressor will cycle off/on , and the fan speed also . All 3 parts , are relatively not expensive . Be sure to get wire connectors because they do not come with these parts .
Posted on Apr 14, 2010
Testimonial: "Gave excellent help and advice. "
Sea Breeze
  • 4655 Answers
SOURCE: Have a GE Profile PFS22MIBBB. Just replaced
You will need to unplug the fan and test the voltage coming from the board. You should have 12 to 13 volts DC. Unless you place a fan on condenser that blows air to keep it cool until we locate the problem the compressor can be damaged from over heating. Click here=> GE ARTICA PROFILE TECHNICAL INFORMATION On the first diagram the tech sheet and look for J2 that has both sets of wires for evaporator and condenser fan motors. With new board and new fan you must have a bad connection in the wiring harness. Click on wiring diagram and it will open in a new tab as a Service Manual. Look it over and ask me questions as communication will be very important for you to be able to understand all of this. I will be here when ready so please let me know. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Jun 04, 2010
Sff4ds11. condenser fan not working?
Sound like a clicking solenoid/relay. The relay is bad. Basically it's not holding to supply constant current to the fan motor. Without being plugged in !!! (unplug the fridge) spin the fan with your fingers, if the fan spins freely then there shouldn't be an overload. Relays and solenoids are more apt to fail than a motor. Also check under the refrig, many have a timer and temperature sensor which can be adjusted.
May 18, 2018 | Refrigerators
Condenser fan on heat pump does not turn off
If it is just the condenser fan that means you have a fan relay that has welded shut. Turn power off to your unit and trace the wires from your condenser fan back into the control panel at the unit. You'll have 3 wires going to it. 2 go to the run capacitor and one goes to the fan relay. The one that goes to the fan relay is the part that needs to be replaced. If you have no fan relay and it goes to the main contractor, half of your main contractor is welded shut and will need to be replaced.
Sep 18, 2014 | Carrier 52PQ-515---3 Premier Series Heat...
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
What can i do if my fridge is not cooling?
Hello and Welcome to FixYa!
Refrigerator mal function can be due to several reasons...To trouble shoot poor/no cooling problem, you need to carefully check all the below quoted possibilities one by one:
  • Start Relay (Compressor Clicking won't Start in case of faulty).
  • Bad/dirty Condenser.
  • Defrost timer Settings.
  • Cold Control Settings.
  • Defrost (Ice built up on the evaporator coils that chokes the air flow to the freezer/refrigeraot compartment).
  • Evaporator Fan.
  • Main Control Board mal function.
You need to cross check all above quoted possibilities one by one to locate/trouble shoot the problem.
Best of Luck,
Your token of appreciation in form rating will be highly obliged.
Concerned.
Sep 18, 2010 | Avanti Refrigerators
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
Replaced capasitor/relay combo capasitor melted restarted made full bend of ice (dumped 12-15 ) times now three days later freezer is 50 and refrig is 57 compressor is not hot sounds good thinkink defrost...
The melted capacitor and relay is a symptom of a serious problem, high amp draw. Much of the time this is caused by a plugged condenser (dirty). The only thing that can draw enough amps to melt those is the compressor which means, you might have a bad compressor if you kept the condenser coil clean.
The defrost timer has a dial on it. Turn it clockwise and see if the unit begins to work. If the dial won't turn, the timer is bad and should be replaced. If it turns and you hear a :"click" yet the unit doesn't work, your relay and capacitor are probably done for. I'm assuming you got a "3in1" electronic relay capacitor overload. They can't take the amps the original relay can.
Jul 08, 2009 | Frigidaire Refrigerators
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Relay won't stop clicking
Matt, sounds like you have a main board problem here. The main board is on the back side of the refrigerator. If you are handy with a meter you can do some checks. Is the clicking relay coming from the main board? If it is, than it's more than likely your problem. First check the voltage from connector J7-9 (orange wire) to blue harness to the left, terminal marked line. This should have a steady 120V, no fluctuation. If you don't have this, replace the board. You want to make sure that the condensor fan motor and evap fan motor are not shorted. A shorted motor will take out the board. At the fan motors harness, with the power off, if you read less than 1K ohms between white to red or white to yellow it's bad. This is for both the evap and condensor fan motor. The part number for your board is. WR55X10543...Catriver..post back.
Mar 11, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
GE 21.9 Cu. Ft. Side-by-Side Refrigerator - Bisque-on-Bisque Logo
46 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
