Question about Amana Refrigerators
Freezer is covered with "snow" - Amana Refrigerators
    Sergeant:
    Champion:
  • 351 Answers
Door may have left open or door seal going bad. getting air from some where.
Posted on Oct 08, 2010
My may tag fridge GS2126PADB seems to run fine but the freezer is not blowing cold air and fridge & freezer are warm.
There are more than reason: first check the fan in the upper part of the freezer (you have to unscrew 3 bolts of the cover),second check the freezer door sealing,third is to check that the cooling tubes inside the freezer are cold enough without heavy snow (you have to unscrew about 6 bolts of the cover),Heavy snow reduces cooling and it means that the timer is not working or the heater is not working.I hope to help you in reform
Jun 27, 2014 | Amana ARS266ZBS Side by Side Refrigerator
Kenmore elite refrigerator
You have a sealing issue I'm guessing you have an ice dispenser on the door that is letting in warm air. If not your gaskets need to be replaced
Aug 10, 2013 | Refrigerators
Refigerator and freezer all of the sudden don't seem to keep cold enough
The back wall of your freezer covered with snow? If it is I would suggest you replace the heater and a thermistor - Heater: WR51X10101 Thermistor: WR55X10025. If no snow then it is probably the main pcb: WR55X10656
Mar 24, 2013 | GE GSH22JFT Side by Side Refrigerator
Hi fridge was not staying cold so i looked at the coils in the freezer and they were cover with snow(ice), I melted the snow and ice and it worked good for almost 2 weeks then started getting warm again...
Its definatly a defrost problem. The reason it stopped cooling is because there was no air circulation do to the ice build up. For the most part the part you'll need t replace is called an adaptive defrost control, the part number for it is 12002104. This part is located in the refrigerator side of the machine, above the heading so you'll be taking the hole top down to put it in. Take your time and it won't be hard.
Nov 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE GSS25JFM Side by Side Refrigerator
The back wall in the frizer cover with "snow".What is the problem?I open cover -ice and snow.I onplug fridge for mealt .What is next step?I I think defrosting is not workng.What to do?
heatman101
Aug 31, 2010 | GE Refrigerators
Snow in the freezer
If you are noticing that you often have "snow" if the freezer, this is an indication of one of two things. 1. Are you putting food into the freezer while it is still hot? This will cause condisation to form, and if it is done often enough, this will lead to "snow" 2. The other reason that this might happen, and the more likely of the two is that the door is either not being closed completely, or the door seal is leaking allowing room air to enter and condense in the freezer. Hope this helps.
Apr 01, 2010 | Freezers
I have a kenmore refridgerator side by side. The freezer is beginning to have snow buildup (it is a self defrost) the refridgerator side is not cold
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Could you find a model number like 321.256489 for example then I can find the parts to look for. Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
