Question about Franklin Industries Franklin Chef FIM200 Ice Machine
Model fim70 will not harvest complete leaves front row of ice and sheet builds up and has to be shut down in order to defrost harvest cycle any suggestions does the sensor on the evaparator need to be moved ? is there a way to make the defrost cycle longer ? any help would be appricated I have only Worked on Scottsman and Manitowoc Ice machines have not been schooled on Franklin my Name is John Corrigan Phone 510-276-9118 I am doing this as a favor for my parish in Oakhurst Calif I a a retired Journeyman hvac/ r mechanic just need to have some in put where to start and if this is a inhearant problem also just as the unit starts into harvest mode there is about 2-3 inches of frost on the suction line and the high side tubing is hot I do not think it is a compressor problem /control?/
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: Manitowoc Icemaker Compressor Will Not Start
I'd think that the start capacitor is faulty and could be the problem.
Here's a parts list for the model you're working on that also contains several line drawings
http://www.manitowocice.com/documents/miien/service/partsmanuals/icemachines/qseries/qmodels/Q1300.pdf
Here's the online service manuals for the ice machines.
http://www.manitowocice.com/service/servicemanuals.asp
Just click on the link to expand the search and go down until you get to the "Q" series and select the "troubleshooting guide" and any other parts of the tech manual you need, it's all there including the technician's guide too.
Hope you found this info very helpful and best regards!
Posted on Aug 07, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: left the wash cycle on all night now ice machine
Cycle the drop door by pulling it open as if a load of ice just dropped
Posted on Oct 05, 2010
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
WHY scotsman iec machine shuts down on the refridgeration light ON CM3 CONT
Is the machine producing ice thick enough to come off the evaporator plate? the machine will try to harvest 3 times before it locks out on long harvest. Harvest cycle: The compressor and hot gas valve are both powered during the harvest cycle. The fan and pump are off at this time. The machine stays in the harvest cycle until the evaporator thermistor senses 52 DEG F. If the bin is not full, the unit goes into another freeze cycle. I would check the Thermistor
May 28, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
MACHINE DOSENT HARVEST
be sure the thickness sensor is not turned out too far
Apr 03, 2014 | Ice O Matic Complete Units ICE0500HA
My undercounder KUIS18NNJB5 icemaker freezes successfully but the ice does not exit the freeze plate completely during the harvest cycle. When the next ice cycle starts, the ice refreezes to the plat
In the manual the fix is to clean the ice maker with cleaner. Your ice slab is not releasing during harvest. The plate (evaporator) has minerals on it and needs to be cleaned to remove the build up. On the door of the unit has cleaning instruction, do not short cut the cleaning process, this does take about an hour and follow the instruction to the letter.
This is not a major issue, just cleaning is needed.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 07, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
Have a mantowac 150 Model # BD0152A, plug it in and it begins the freeze cycle and will go thru the harvest cycle once or twice then it kicks off and everything melts. I can reset it and it will start the...
It is going off on a safety limit. Either taking too long to harvest, or too long to make ice. When you switch on, the pcb will flash once or twice. The manual , or usually a printed sheet inside the lid, will tell you which limit has been exceeded and what the likely causes are.
Sep 20, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
SCOTSMAN MODEL #CME506WS1F
You need to descale the water circuit according to manufactures instructions. Scale build up keeps the ice from releasing during harvest cycle. If overall ice thickness is to thick, rotate the ice bridge thickness screw at the top of the platen countercloclwise about 1/8 of a turn max between freeze cycles until desired thickness obtained. If you do not know the correct descale solution alway use a nickel safe descaling solution.
Dec 03, 2012 | Scotsman Ice Maker WBin Flake Style water...
Does a Hoshizaki Model F-1001MWH have a Defrost cycle? As far as I know the "defrost" is the harvest cycle correct?
Ice makers defrost is the harvest cycle. The purpose of a defrost cycle is to clear any ice build up, right?
Jul 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Does a Hoshizaki Model F-1001MWH have a Defrost cycle? As far as I know the "Defrost" is the harvest cycle correct?
flakers usually make ice continually. It utilizes an auger that rotates in a freezer barrel. It scraps the ice of the insides of the freezer barrel and forces it to the top and out. No harvest cycle is utilized.
Jun 10, 2010 | Hoshizaki F-1001M Flake Ice Maker
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
Feb 21, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Franklin Industries Franklin Chef FIM200 Ice Machine Logo
Top Franklin Industries Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Franklin Industries Kitchen Appliances - Other Expert? Answer questions, earn points and help others
