Question about Sport & Outdoor - Others
Body express rock & roll stepper manual - Sport & Outdoor - Others
How do I find the stepper motor on a 2003 Buick Rendezvous?
On the Throttle Body
Doubt it failed
Best make sure you have no cylinder misfires
& are not loosing throttle plate data or tps data
DO NOT replace parts
Have a professional road test with scan tool, to look at data
You need to do every thing to learn the vehicles systems
& find a problem & avoid replacing the throttle body, due to
lack of knowledge
Get some CRC Throttle Body Cleaner & read the
back of can
Aug 12, 2014 | 2003 Buick Rendezvous
How do I find where the stepper motor is located on a 2004 trailblazer
Here's a step by step. http://forums.trailvoy.com/showthread.php?t=48886
Jul 05, 2014 | 2004 Chevrolet TrailBlazer
My 2004 Nissan Frontier 4x4 won't reverse. I'm thinking the band is slipping because when I park the truck on a hill and put it in reverse and let it roll back it works until you come to a stop then i
Remove the valve body & clean all the valves & bores
There is video on that you can watch.
You don't put any trans in reverse, unless you have your foot
on the brake & you don't let it roll back
I have a 3 week old 2014 Frontier
It tells you that in the owners manual
Google 2004 RE5RO5A trans issues & see what turns up
Your TCM should be outside the trans
2008 on, are on top of the valve body in the oil
Apr 07, 2014 | Nissan Cars & Trucks
I have a tony little rock n roll stepper and the LCD counter is not working. How do you repair it?
Obvious question, did you try a new battery?
You can also try cleaning the battery compartment in case of loss of the contact between the battery and the holder.
Oct 23, 2013 | Sport & Outdoor - Others
My service engine light is on. and I took it too autozone to be checked and got the results: Large vacuum leak on engine, 2. throttle body condition-dirty and faulty IAC valve/throttle. what does this...
These are all things that can affect your gas mileage and engine performance.
To check for vacuum leak, look for unhooked hoses on top of engine. If OK, use starter fluid and spray along intake manifold gaskets with engine running. If engine speeds up, there is a leaking gasket.
IAC deals with idle. Does the car idle smoothly? If not, remove IAC to see if it's dirty. I will paste instructions below for the IAC valve.
Throttle body dirty--what code is this? never heard of such a code, but you can clean the throttle body wioth carb cleaner. I will paste instructions below.
IAC valve info:
Operation The amount of air taken in during idling is regulated by the opening and closing of the servo valve located in the air passage that bypasses the throttle valve. The servo valve is opened or closed by the activation of the stepper motor (incorporated within the idle air control motor in the forward or reverse direction. Battery positive voltage is supplied, by way of the MFI relay, to the coil of the stepper motor. The engine control module switches ON the power transistors (located within the engine control module) in sequential order, and, when current flows to the stepper motor coil, the stepper motor is activated in the forward or reverse direction.
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Detach the electrical connector at the sensor.
  3. Remove the sensor from the throttle body.
To install:
  1. Install the sensor in the opening in the throttle body and tighten the sensor.
  2. Attach the electrical connector to the sensor.
  3. Connect the negative battery cable.
Testing
Checking Coil Resistance
  1. Disconnect the idle air control motor connector and connect the jumper (test harness).
  2. Measure the resistance between terminal (2) of the connector at the idle air control motor side and terminal (1) or terminal (3). Standard value: 28-33 ohms at 68°F
  3. Measure the resistance between terminal (5) of the connector at the idle air control motor side and terminal (6) or terminal (4). Standard value: 28-33 ohms at 68°F
  4. If not within specifications, replace the IAC Valve.
  5. If within specifications, check connectors and wiring between the sensor and ECM/PCM.
Checking Operation Sound
  1. Check that the operating sound of the stepper motor can be heard over the idle air control motor when the ignition switch is turned to the ON position (without starting the engine).
  2. If no operating sound can be heard, check the stepper motor drive circuit. (If the circuit is good, a defective stepper motor or engine control module is suspected.)
    IAC picture--mounted on top side of engine.
      Throttle body--loosten clamp to right of throttle body and pull hose off. Use electric parts cleaner or carb cleaner--spray on dirt with engine running. don't touch any sensors inside throttle body--sensors are delicate.
    Oct 11, 2010 | 2005 Mitsubishi Endeavor
    No manual for Medicarn body slimmer
    Try ringing Medicarn customer services in Sheffield.
    01142329006
    Jan 13, 2010 | Stamina Products Stamina Instride Plus...
    Compatibility with PCI Express x8 motherboard
    you rock i got the xxx version but those rock and yes it will work im on pci 8x it will just adjust the performance to 8x instead untill you get a 16x but xfx is a good company consumer suport is good
    Apr 21, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
    Sport & Outdoor - Others Logo
    196 people viewed this question
    Top Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
