Question about Roper Dryers
When I tested the dryer for renting my property, it came on, but when I opened the door it would not turn off. I turned it off manually. Now it will not start - It is a Roper REX4635E. How old is this dryer?
  • 262 Answers
I would first change your door switch. This might solve all your problems.
Posted on Oct 06, 2010
Dryer still tumbles even when door is open. It will turn of and stop when i turn it manually to off
The door actuator mounted on the door or the switch mounted on the dryer is missing or broken. The dryer is supposed to stop if the door is opened. Replace the door actuator or the switch.
Mar 03, 2015 | Dryers
I am 60 year old property manager. Due to my age and my full time job, I would like to find a way to collect rents of properties I manage automatically. There are about 12 of them and they are pretty
Google "square up" there is an android app "square" ... I don't know if right for you, but it is very versatile and easy to use. Check it out
Nov 25, 2014 | Computers & Internet
When turning on dryer all lights are on but dryer won't start?
I don't have the code list for this dryer, but I'm thinking the door switch maybe the problem.
Sep 28, 2014 | Whirlpool GEW9250 Electric Dryer
How do I read the owners manual for model FGRB6600FSO
Instructions Operating Problems
  • 1 Check your dryer's power supply. Reset any flipped breakers, and replace any blown fuses.
  • 2 Open the door, shut it and press "Start" to be sure an open door isn't hindering the dryer's operation.
  • 3 Turn the dryer's control dial beyond "Off," into a cycle selection, before starting it.
  • 4 Check the gas supply valve. An opened valve will appear parallel to the line. If it is perpendicular, turn it to open it.
Jan 15, 2013 | Frigidaire Electric Dryer
Dryer was working fine, and it just stopped, door switch is ok
Stopped turning and clothes still wet ? Was the timer still in the duty cycle ? Can I assume the door was properly closed. There is a safety switch on the door, open the door and find it. With the power off try pushing on the lever to activate the switch manually (with a tooth pick etc.) If you can hear a distinct click it is probable OK. If you want to test it with a meter you will need to open up most machines.
Jun 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer doesn't turn on. Replaced the power switch
Power switch? Do you mean push to start switch? To see if you have a bad push to start 1st unplug. Open back top panel. Only do this test if you hae two wires going to the push to start switch. Wear gloves so you dont kill yourself. seriously. If you do have two wire then disconnect from push to start. Make sure they are not touching anything!!! Plug machine in. Tunr timer to 60 minutes. Touch wire together then pull apart. If machine kick on replace push to start. If not put everything back the way it was. Jump out door switch. If door switch is jump and still dont work then check motor test. Check harness on motor. If has a capacitor need to check with a cap. tester. You need a service manual to test wheather you have a bad motor. The manual will show you how to properly test a motor (each lead has ohms valve and you have to know what they are to test)
Mar 25, 2010 | Whirlpool LEQ7030KQ Electric Dryer
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Dryer would not start but as i kept turning start switch it came on
timer switch is going bad go have it tested
Apr 23, 2009 | Dryers
Dryers Logo
42 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
