Question about Motorola Mobility SLVR L7 Cellular Phone
Charging When i plug my charger in, my phone lights up but it doesn't get charged. How can i fix this?
I don't think you can.
I have a slvr and this has happened twice.
The first time I sent it back and they replaced the battery and then it worked fine again but now it has happened again and I can't be bothered to send it back again.
I have heard that it is because when you leave the charger in the phone for too long the battery becomes unusable. So I guess the only solution is to replace the battery and make sure you do not keep the charger in for too long at a time.
Posted on May 28, 2008
    Sergeant:
  • 282 Answers
First check both charger and battery.
3 Suggested Answers
pingping
  • 111 Answers
SOURCE: Razr V3i charging problem
Hi V3 is very fragile and if you use the incompatible accessories, you can ruin their ports easily. One weak point of V3 Phone is the SIM card Port is not an opening flap like other GSM phone but using pin and spring Port style which is mean you have to push your SIM card in and use the SIM Card edge to push the pin down in order to contact with SIM metal area interface. But by pushing force is varied from users so too strong and too hurry will damage the pin. If one of the pins is damaged, when you slide the SIM card in, the contact is missing of one or two pins due to damaging of the pin cause the error message "Insert SIM". In this case, only way is needed to replace the SIM Board underneath. If you can do it yourself, please follow the instruction pictures below. If you are not sure and never do this before, I suggest you send the unit to Motorola Repair Center. Your SIM Card Board and charging port will need to be replaced. http://www.itsjustmerob.com/files/V3_Razr-repair.pdf This is a Full Motorola V3 Officially Service Manual and even the Motorola Repair Center also has this one. so copy this link and print it out. Around hundreds plus pages but can be your Guide which you cannot find anywhere else. I gave it to you free but I have purchased it before. Hope that you can get it fix. Other solution is looking V3 parts on sale a lot on Ebay and use them to replace part to your phone will be cheaper if your phone is no longer under warranty. If it is still under cover then send the unit to them and don't spend time and money to do it yourself. But if it is out of warranty and want to avoid costly repair then use the method in the manual I provided you and you will be able to get your phone fix. Good Luck
Posted on May 15, 2007
ahlrub
  • 283 Answers
SOURCE: V3 not charging
it's a hardware failure,, cant fix it here ..
Posted on Apr 16, 2008
My htc incredible s won't charge, I've tried
It sounds like the charging port on your phone is broken. This could have happened a number of ways. Either by dropping your phone, putting the charger in wrong, or taking it out wrong. If you call HTC(866-449-8358) and it is still under warranty they will probably fix it for free as long as it doesn't have any water damage(http://www.ehow.com/how_4479971_check-cell-phone-water-damage.html). Otherwise you could also get a new phone.
Oct 19, 2012 | Cell Phones
My Nokia E73 won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 15, 2012 | Nokia E73 Mode Cell Phone
Wont charge
First Option:
Second Option:
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
Wont charge
First Option:
Second Option:
Sep 09, 2012 | AT&T Avail
My casio rock wont charge
First Option:
Second Option:
Aug 31, 2012 | Casio G'zOne Rock Cell Phone
Battery will not charge
First Option:
Second Option:
Aug 14, 2012 | Samsung Intensity II U460 Verizon
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
Second Option:
Jul 26, 2012 | Huawei Impulse 4G
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
Hi, my blackberry Curve isnt charging and ive tried several chargers, there is no light indication showing that it is charging what do i do? i dont have enough money for a new charger HELP
This kind of fault is only limited to a few causes.
First of all, it is not likely that all chargers you have tried are bad. So the fault is definitely coming from the phone. it is most likely that the charging port on the phone is bad and needs replacement of needs to be worked upon. This may not be very expensive depending on your location and the extent to which the damage has been done.
Also, it is very possible that the power source is not good enough to charge the phone. As such, you might be required to plug the phone's charger into a number of outlets that you are sure are operating fine. This would help you determine if the fault is coming from the charger, outlet or phone.
Lastly, if you are just trying random chargers, you would have to get a charger that you are confident is working and you have to try it. If it still doesn't work, you have to send it to a repairer as trying to fix the charging port yourself could let to a more serious damage to your phone.
Hope this was helpful?
Jun 19, 2011 | RIM BlackBerry 7290
When i plug my charger in i have to move it around for it to start charging and if i move my phone it quits charging its not the chargers i have tired im thinking it my phone. what do i do?
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced.
To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
May 07, 2011 | Cell Phones
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
