Question about GE Advantium 120 Convection/Microwave Oven
My 240 Advantium (SCA2000BBB 03) had worked great for 10 years and then the Microwave stopped working intermittently and then finally completely. A local repairman replaced a micro-switch in the door latch and after a month the microwave is not working again. The lights still work fine. Would it be likely that the micro-switch failed again or is something else wrong?
SOURCE: Repairing Microwave
check high volatage circuit, and magnetron, and wiring and control unit or circuit...
Posted on Oct 05, 2007
  • 338 Answers
SOURCE: GE Advantium Microwave not heating food
If you want it fixed call sears for service. I would not recommend taking this microwave apart if you dont work on them for a living. only because there are 14 million thing that need to be remove to do a simple repair.
Posted on Dec 04, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Advantium SCA1000 not heating
That would be 'the primary interlock (top door switch), or its mount may be loose or cracked.
It may be a coincidence, or not. Hard to say.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
But it could be misalignment from the door work. Too bad he didn't just replace the door handle. That's such an easy job.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 29, 2009
  • 298 Answers
SOURCE: Fans and lights don't work on our Advantium
Some relays must have got stuck open. Check the following schematic. You should check the Main relay, RY14 and RY15 for lamps and relay RY6 for the fan.
http://www.microwavedisplay.com/advantium_sca1000_sca1001_sm.pdf
For your own safety, always make sure you are working safe. Microwave units can be very deadly. Consult an expert if in doubt.
Posted on Jan 04, 2010
heatman101
  • 43501 Answers
SOURCE: The microwave portion of my Advantium sca2000bbb
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fssf
Posted on Sep 30, 2010
The microwave portion of my Advantium sca2000bbb 03 stopped heating. halogen heating still functions. Sounds normal when running
heatman101
fssf
Sep 26, 2010 | GE Advantium SCA2000B Microwave Oven
GE Advantium won't heat
Actually, these have a 10-year warranty on the magnetron and on the halogen speedcook lamps.
GE will even send you the magnetron to replace it yourself. Call them at 888-239-6832.
The full service manual with installation instructions is here.
Part ordering help (if you need other parts) is here.
I'd recommend that your bookmark this link to your favorites.
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward. Thewy are in the service manual.
You can also download GE owner's manuals and installation instructions
here.
If you prefer to replace it though, I would suggest doing Google searches to try to find 240V microwave ovens. They're the exception.
Jan 10, 2010 | General Electric Microwave Oven
Fans and lights don't work on our Advantium sca2000bbb. Display does. The main fuse is OK. Is there another?
Jan 04, 2010 | GE Advantium SCA2000B Microwave Oven
My sca2000bbb the convection works fine and the microwave does everything but heat up the food thanks for any help
If the microwave side is not cooking, it may be the magnetron has died, if so, it may be expensive to repair and you may have to consider another purchase.
Oct 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
Oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Apr 15, 2009 | GE Advantium SCA2000B Microwave Oven
GE Advantium mircrowave oven
The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
Apr 09, 2009 | GE Advantium SCA2000B Microwave Oven
Advantium readout flashing
I would say it is a sign of trouble.
Not to say that it's catastrophic, but on these models part can be pretty expensive.
We regularly repair such control units for customers nationwide by mail for in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Dec 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Dec 04, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
