Question about E-Machines T5088 PC Desktop
When i press the on button, the fan comes on and three beeps that follow and nothing else happens.
  • Doctor PC
    Doctor PC Oct 06, 2010
    I wonder that your PC is dead! Did you see anything on screen? Waht OS do you have?
    Master:
  • 388 Answers
Three beeps indicates a ram (random access memory) problem remove on at a time ensureing the computer is switched off and power cable removed leave it for 10 mins before opening the comp as there could still be electricity or static inside the unit.
Posted on Oct 06, 2010
When I go to make the settings - as per manual it comes up P1 3:20, but when I press the 'menu' button nothing seems to happen. I expected to see P2, P3 etc so my white bread (P1) is terrific
Sometimes the little buttons underneath are not centered properly. Try pushing around the edges of the "menu" selector button your machine makes a "beep" sound" If you never feel the button move under your finger followed by the "beep" sound then your selector menu button may be broken.
Apr 16, 2013 | Russell Hobbs 18036 Breadmaker Fresh Bread...
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Power light comes on but nothing happens
What type of laptop? What operating system?
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 22, 2012 | Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
3 beeps and fan running at start up
The three beeps shows the Memory Module Test and that symbolise that the memory module is having a problem and to my knowledge when there is a problem with the memory then you have to open the casing and remove the memory module and clean the slot very well and if slot in back and the memory do the same change the to the second memory slot if it happens there again then you change the Memory module.
ok
rate this solution.
Oct 06, 2008 | Gateway GT5408 PC Desktop
T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Aug 30, 2008 | IBM ThinkPad T30 2366 Notebook
Manual and Troubleshooting resource for InterAct V3 Racing Wheel - Sony PS2
Hi there 78 Racer, Press SET button the LED light will start to blink and beep once. Press the square button on the right hand side of the wheel. This will set it to Digital and pressing the circle will change it back to Analogu. The LED will stop blinking and a double beep sound indicates it's been set - that's it
Aug 20, 2008 | Cables Unlimited InterAct Racing Wheel V3...
E-Machines T5088 PC Desktop Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
