Question about Sager NP-5620-C Notebook
I need to replace the CMOS battery on the notebook.. The time and date resets every time turn off the computer I can not find the CMOS battery-Do you have any idea where it is physically located The model number on the bottom of the computer is 5600P
  • Doctor PC
    Doctor PC Oct 06, 2010
    Is inside the case.You will need to open it and replace your batt.
    Master:
  • 388 Answers
Try under the front panel which just pulls off you are looking for a silver round watch type battery about the size of a two pence piece or they sometimes coat theem in plastic blue or black with a red and black wire coming out of it.
Posted on Oct 06, 2010
How do i bypass cmos battery
You need to have the battery in order for system to boot, however, you can reset it.
http://www.howtogeek.com/131623/how-to-clear-your-computers-cmos-to-reset-bios-settings/
How to Clear Your Computers CMOS to Reset BIOS Settings
Oct 06, 2016 | Computers & Internet
Tip
How to verify that the CMOS battery needs to replace
<p>The CMOS battery is named after the Complementary Metal Oxide Semiconductor power. The CMOS has the current date and time functions for desktop and laptop computers. It allows the computer to automatically adjust the time, even on computers that are disconnected for long time. When a computer no longer has the date and time and forget it on every boot, the CMOS battery probably needs replacing. Some computers have messages when the battery is weak, while others just lose the current date and time after each shutdown.<br /> <p>Time & Date Errors<span> </span><br /> <p><span> </span><br /> <p>1. Turn on the computer. Look in the task bar at the bottom right. Make sure the date and time is set correctly. Double-click the time and click the up or down arrow to switch to the correct time. Click on the arrow next to month to change the month. Click "OK" when finished.<br /> <p><br /> <p>2. Turn off the computer. Wait 3 to 5 minutes and start the machine.<br /> <p><br /> <p>3. Look on the taskbar to see if time was lost and said a strange date January 1, 2000. Replace the CMOS battery, if this is the case.<br /> <p><br /> <p>CMOS Error Message<br /> <p>1. Look for error messages like "CMOS checksum error", "CMOS Read Error" or "CMOS battery failure" when you start your computer. These errors are caused in the machines shut down for several months or when the CMOS must be replaced.<br /> <p><br /> <p>2. Let the computer on for 24 hours. Restart the computer and find the error.<br /> <p><br /> <p>3. Change the CMOS as the return error.<br />
on Jun 21, 2011 | Computers & Internet
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
Is my CMOS battery the problem to the time and date not automatically correcting itself, or is it something else?
The CMOS battery is the main cause of your time resetting. Although it usually resets further back. Double check your time setting in the operating system itself. If everything is correct then the source of the problem is more then likely the CMOS battery. Batteries are pretty cheap so not hard to replace. If it is a desktop computer (if you're comfortable with it) open up you computer and what looks similar to a watch battery and that is what you will need to replace.
Note* IF it is the CMOS/ BIOS battery it will only reset the time when you lose power to the computer or turn it off.
Oct 04, 2012 | Computers & Internet
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
May 27, 2011 | Computers & Internet
Everytime I turn on my computer, I have to do F1 and reset the time and date. How do I replace the battery? It has gotten so bad, sometimes I have to press and hold start button, turns off and restart it
Hi philco1977,
Good day. The BIOS prompts you to press F1 key and reset the time and date in your system. This is caused by a CMOS battery that needs to be replaced in your motherboard which is unable to save the time and settings in your computer. In order to replace the CMOS battery, you must open your computer and in the motherboard you may see a coin cell battery. You can take it out using you hand or you may use a flat screw driver or a knife. Make it sure that when you do the replacement the computer must be turned off. Once you are done with the replacement you may have to go again to the BIOS and reset the settings again including the time and date and it will never prompt you anymore to reset you time and date settings.
Thanks,
allanhunt
Apr 22, 2011 | Computers & Internet
My date has to be reset every time I turn on my computer. How do I ensure the date and time is memorised thereby avoiding resetting. Thank you.
most of the cases the main reason behind the date time reset problem occurs due to weak CMOS battery on the motherboard. So, you just need to change your CMOS battery on your motherboard to resolve this problem.
Mar 29, 2010 | Computers & Internet
Need to know how to reset power on password for hp
If this is a BIOS Lockout Password, then you would need to Pull the CMOS battery From the laptop... Which most likely means Complete Disassembly of the laptop just to get to the battery... You would have to unplug the battery... Make sure the Laptops Charging Battery is also Removed and the AC Adapter is NOT plugged in...
Once the CMOS battery is removed, Hold the power button down for 30 seconds... then replace the battery and see if it is bypassed/removed..
There is a good chance that the BIOS password is on a security chip on the motherboard and if this is the case, then pulling the CMOS battery will do you no good... You will need to replace the motherboard if this is the case...
Nov 16, 2009 | HP Compaq 6510b NoteBook Intel Core 2 Duo...
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
Sager NP-5620-C Notebook Logo
171 people viewed this question
Top Sager Computers & Internet Experts
David Payne
David Payne
Are you a Sager Computer and Internet Expert? Answer questions, earn points and help others
