Question about Jazz DV-179 Digital Camera
Flash setting cannot be changed to Automatic
The flash setting cannot be set to "Automatic" or Flash on. The flash will not function and tried changing settings. Tried in settings.
  • suprmario51 Dec 25, 2008
    ever since the flower icon appeared on my screen I can't set the auto flash.
  • 90 Answers
Please call customer service at Jazz Products 732-572-7050
Posted on Jun 30, 2008
Unlock Child lock on nissan if the lock is on and dont open from outside
All doors lock automatically when the vehicle speed reaches 15 MPH (24 km/h).
? All doors unlock automatically when the ignition is placed in the OFF position.
The automatic unlock function can be deactivated or activated. To deactivate or activate the automatic door unlock system, perform the following procedure: 1. Close all doors.
2. Place the ignition switch in the ON position.
Within 20 seconds of performing Step 2, push and hold the power door lock switch to the position (UNLOCK) for more
than 5 seconds.
4. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
5. The ignition switch must be placed in the OFF and ON position again between each setting change.
When the automatic door unlock system is deactivated, the doors do not unlock when the ignition switch is placed in the OFF position. To unlock the door manually, use the inside lock knob or the power door lock switch (driver's or front passenger's side).
NOTE:
The automatic door unlock function can be changed using the Vehicle Settings in the vehicle information
Sep 30, 2016 | Nissan Pathfinder Cars & Trucks
Turning flash off on Nikon D60
Based on what you said, it appears that you want to know how to turn the flash off on your D-60.
On my D-90, you do this by rotating the mode switch on the top center left side of the camera one click counterclockwise, from the green automatic setting, to the white automatic with no flash setting.
You can also change flash settings from the menu. For my D-90, the manual says you use custom setting "e2." Check your manual for the D-60.
I never turn my flash off from the menu because it takes too long to turn it back on when you need it. Another alternative is to simply hold the on-camera flash in the down position while you shoot.
Apr 19, 2014 | Nikon D60 Digital Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
How do make the flash work?
Good day, click the link below and download manual. hope it will help to your problem.
users manual
thank you.
Jul 26, 2010 | Vivitar ViviCam 8025 Digital Camera
Remote control RM-810
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching
1. Turn on the TV
2. Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once.
3. Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on.
4. Release both buttons. The indicator light will flash constantly indicating the automatic search mode.
5. After the indicator light illuminates, release the two keys simultaneously.
6. If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller
7. Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
I think my flash is too bright?
Make sure that the exposure compensation is at zero. If that does not work, make sure that the flash is on automatic brightness. Check the manual if you do not know how to do either one of these.
Apr 11, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Automatic zoom
auto zoom will only work while the build-in wide-flash adapter is slided inside.
Apr 05, 2008 | Nikon Speedlight SB-600 TTL Flash
Flash settings Sony DSC-H7
Okay, I figured out the answer to my own question!!!!! The REC mode has to be set on normal in order to change the flash settings. If it is set on burst you will not be able to change the settings.
Mar 02, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
NIkon Coolpix 2100 Digital Camera
Change the setting off from automatic. Choose Flash for all your pictures.
Artgirlny
Aug 31, 2007 | Nikon Coolpix 2100 Digital Camera
Jazz DV-179 Digital Camera Logo
222 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
