Question about SanDisk Sansa Clip MP3 Player
Sansa clip 2gb
My sansa clip 2gb wont charge or allow to b sync at all
  • piggy24 Aug 20, 2008
    i've tryed a billion if not a billion and one times to get this thing to work. every time i try to listen to a song, it says to sync. so i synced it and it keeps telling me to sync it.
  • Anonymous Apr 01, 2014
    my sansa clip was playing and just went off and will not come on
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 28, 2008
Hello i have a sansa clip 2gb and the music is showing up when i check the files but does not on the clip itself. it says "No song" I know i added the songs on there. can you help me?
try using windows media player to transfer the music...here's how 1.Update WMP to version 10 or 11 2.goto sync tab and yoyc player must be detected. 3.create a playlist of songs you want to transfer 4.click on start sync to transfer music to your player.
Sep 03, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb wont charge when i plug into pc. i go into my computer and it wont recognise it. the screen lights up and says connected and acts like its charging ie the battery indicator flashes but after...
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Charging my 2gb sansa clip
You can charge it by leaving it plugged into the computer for 3-4 hours (usually less).
Nov 12, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB rarely turns on.
-Tha Mp3 Doctor
Oct 20, 2008 | SanDisk Sansa Clip MP3 Player
Sync
What you will have to do is transfer a new song from the subcription company..or you can try to format the device (formatting will delete all the data) and then your device will be back in working mode..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Sep 19, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB...WMP11 will recognize, but will not list in device pane in Sync mode...
Hah, figured it out! Had to roll back my version of WMP, which can simply be done by (in XP) going to Start > Control Panel > Add Remove Programs, and then click on WMP11 in the program list. Click remove, and it will ask if you want to roll back to the previous version of Windows. Click yes, and it will roll it back to the previous version of WMP11. Now, assuming you have an active internet connection, after you restart your computer, it will ask if you want to update your WMP. Click yes, and it will re-install the version you started out with, replacing drivers, .dlls, and anything you were missing before hand. Long story short, the solution was patching the holes in the program. I can now plug my Sansa Clip 2GB into the USB port, and WMP will recognize it right away (I can almost hear a small voice from inside my computer saying "would you like tea with that, mr. guy?" hah). I also found out you can have more than one media player connected at the same time! How cool is that? Great if you're trying to set up multiple players with the same playlists (promotional type stuff, business type stuff, etc.).
Aug 06, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip 2GB
yu charge it erveryday, and yuve been using it everyday, so that means that it needs to charge, if it says connected tocomp and charging that means that it needs more electricity in its battery to keep, its battery running.
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
170 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
