Question about Garmin StreetPilot C330 GPS Receiver
My Tom Tom blew up when plugged into car charger. Can this be fixed? About how much should I expect it to cost?
  • Anonymous May 29, 2008
    plugged into cig. lighter has not worked since
  • 174 Answers
This is a problem with early TomTom CLA (cigarette lighter adapter).
See link for additional information
http://www.satnav-shop.com/index.php?ln=en&pg=6&sec=9
Call TomTom if the unit is still under warranty. Next time Buy a Garmin.
Posted on May 29, 2008
  • Garmin Master
  • 13,433 Answers
It debends on how badly it blew up. Probably more than the price of a new one, contact a repair man and get a estimate.
Posted on May 28, 2008
Tom tom will not switch on when i try to charge it the led light does not come on i have hardly used my tom tom
What is your charging method? In car or house hold plug? Suggest that charger is not working (Green) if light on Tom Tom (at bottom near charger lead) is not lighting. Check your charger and see if you have an indicator light on it showing it is on. If yes, plug in Tom, then press and hold the "on" button for 15 seconds constinuously. Tom Tom should reboot.
May 01, 2011 | GPS
Been given a tom tom, with no charger apart from cigarette lighter adapter, ONCE CONNECTED WHEN SHOULD I EXPECT A RESPONSETO ENABLE ME TO INSTALL INFO. THANKS JENNY
Tom Tom GPS only brings a car charger and a USB to Mini USB cable that allows you to sync with your computer. For more info on your specific unit visit the Tom Tom site. You can also download the needed interface software for your unit at their web site. The USB cable isn't very expensive if you need to replace it. And once you have it, you will be able to update maps or download and install maps for other countries and even some fun voices if your unit supports it.
Download the software you need first and then connect your TOM TOM. Follow the prompts. Install any updates and you should be okay.
Jan 25, 2010 | Tomtom GO 300 GPS Receiver
For some reason, I didn't get a home charger for my Tomtom One 130 when I got it for Christmas. Will my Motorolla phone charger work? Also, I cannot understand the diagram for installing it to the...
The plastic suction cup attaches to your windscreen. You can see more of the device in www.tomtom.com
Your Motorola phone charger will not work and it may even damage your GPS! In the package you have a cigarrette lighter adapter for your car - the home charger (AC-charger) you have to purchase separately.
Jan 06, 2010 | GPS
My tomtom will not turn on. I have had it plugged into the car charger for several hours. Help?
try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
Jan 02, 2010 | Tomtom ONE GPS Receiver
I can't move my dodge charger out of park, why?
I expect the car has a brake safety switch which only allows the tranny to be shifted in to gear when the brake is applied. If this is not happening I expect either the switch or the solenoid it activates has failed.
I hope this may have helped,
Tom
Oct 27, 2009 | 2006 Dodge Charger
I've had my Tom Tom for about two years though haven't used it all that much. When I plug it into my cigarette lighter, it starts to 'power up' but then before long it just quits on me. Nothing after that....
make sure the light is on, on the charger unit. if not then check the lighter plug. ifplug is good then you will need to change the charger
Aug 26, 2009 | GPS
Tomtom only charges on fast charger base. Why?
if it is not charging in the car then the socket in the car is dead, blown fuse or defective socket..
Aug 09, 2009 | Tomtom GO 920 GPS Receiver
Screen is blank, shorted out?
If you had the prongs backwards, you probably blew the input diode. I don't know of anywhere other than Tom Tom for service on these.
Feb 02, 2009 | Tomtom ONE 3rd Edition GPS
Charger
I had the same exact problem! It should plug in to the back of the unit, but it wouldnt charge there either.
What i had to do was goto Radio Shack and buy a Universal Charger for my cigarette lighter that cost $14.00. It has multiple plugs and 'pins'. Find the right one, and set the volt/amp switch to 4 or 6 amps, whatever it says on the bottom of your TOM TOM. The person at Radio Shack helped me, they should be able to help you too!
Thanks,
Mark
Dec 30, 2008 | Tomtom One XL GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
162 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
