Question about Garden
Need to measure for a new one - Garden
  • 8,404 Answers
A new chain??? Take your old chain to the store with you ...
Posted on Oct 06, 2010
Is there a way to figure how many linear ft. a 1,400 square ft. home is that only has 4 main outside walls? So pretty much a square home. Needing to put new facia up and trying to get an estimate.
no
linear measurement is a length measurement and you have given an area measurement
facia timber comes in a set width and thickness so all you have to do is measure around where the facia is to go and that length will be the linear measurement of the facia board
so you get that measurement and go to a timber yard and say you want so many feet of facia board
Dec 14, 2017 | Linear Office Equipment & Supplies
My tape measure will not lock the tape on different measurements
It is broke. Simple. They wear out. Buy another one. If it is new spray it with some lubricate. If you don't have the spray, a new tape measure is cheaper anyway.
Oct 25, 2016 | Measuring Tools & Sensors
I need to know belt sizes
Best way is to buy a new belt as a spare part for your machine or a belt manufacturer might have a listing for your machine in an application catalogue.
Failing these options you will need to measure the old belt or around the pulleys in order to determine the size you need.
Suppliers of belts have a device to measure belts and so a worn belt can still have a valid measurement the belt is turned inside-out first.
If you have to measure around the pulleys don't forget to move the belt adjuster almost back to the starting point first and then measure around the root of the pulleys using none-stretch string or flexible wire and then measure around the top of the pulleys with a flat tape measure.
The approximate length of the belt you need will be half way between the two measurements. Finding the right cross section is more difficult as there is about 20 different types of vee belt sections and multiple other types available though a much smaller selection in common usage for small machines. Your local belt supplier will have a device which will identify which section you need from your old belt or from one of the pulleys or you can download a chart and measure a pulley yourself.
Apr 19, 2015 | Garden
Need wiring diagram or schematic of the primary, secondary, and lighting windings or a weller soldering gun. even arough drawing of the windings that's close would work
You know that's a bit goofy, right? Only the manufacturer would have such information.
If you are serious, you CAN do it. Begin with an accurate Ohmmeter to measure the primary and secondary winding resistances on a new gun (at Sears, say.) To do that, measure the new gun's primary resistance at the plug with the trigger pulled, of course. Remove the gun's soldering tip and measure the resistance of the secondary without the tip and any incandescent bulb in place. (No need to pull the trigger.)
Hopefully you have some of the burned wire from the old gun. Measure the diameters of samples of the burned primary (thin) and secondary (thick) wires with a micrometer. With that information, look up wire gauge information online. You may need 24 gauge and 18 gauge enamel coated wire, for example. Note: a burned wire will no longer have its enamel coating so take that into account when determining the gauge of the "new" wire.
Note the "Ohms/foot" specification for each wire gauge. Divide that number into the resistance values you measured on the new gun (at Sears...). That will indicate the number of feet of each gauge of wire you will need to rewind the core!
Now I'm off to build my own refrigerator... NOT!
Feb 11, 2015 | Cars & Trucks
Were can i get a new drive belt for a tevion usb turntable
If you have the old one measure the diameter in MM and then the thickness. Then put the diameter and the words "Record Deck Belt XX MM" into Google. Check the results and narrow it down using the thickness measurement. You don't need to be spot on with the diameter measurements.
Aug 18, 2014 | Audio Players & Recorders
Hello i have a 2002 audi a4 1.8lturbo. i would like to disconnect the a/c compressor and put a smaller belt on. what would be the new measurment of a new belt that skips the a/c compressor thank you
To get the measurement use a tape measure and wrap around all the pulleys you want to use. Where end meets will be the size belt you need. Allow for any deflection in the spring loaded idler.
Aug 09, 2011 | 2002 Audi A4
How is the case dimention of a wrist watch measured......what is all is included?
If you are looking to purchase a new watch, you have likely seen that there is a measurement for the watch case. This does not mean the box which contains the watch. The watch case is the space between the two arms that extend above and below the watch where the band attaches. The end of the band will fit in between the watch case. You will need to know this measurement both in purchasing a new watch and in looking for a replacement band. Often, watch makers give this number in millimeters, and for that reason, you will need to use a metric ruler to make the measurement.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
  1. Find the watch case. It is the space where the end of the band attaches to the watch face. Refer to the image for a picture of the location of the watch case.
  2. Using the metric ruler, measure the distance from the inside of one of the arms to the inside of the other arm. Watch makers use the inside measurement when creating their watches, not the distance from the outer edges of the arms.
  3. Write down the measurement on the piece of paper. Measure the other watch case, but they should both be the same measurement.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 28, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Need to remove rusted lines and splice new in. I need to know what size the steel lines are?
Find the least rusted part of the line and measure the witdth of the line. It will be either 3/16 - 1/4 - 5/16. FYI tubing is measured by outside diameter and hose is measured by inside diameter.
Aug 04, 2009 | 1998 Pontiac Bonneville
Need to know my wheel base so i can buy a new muffler
get a tape measure, and have someone hold it and the very center of the front wheel.and measure to the rear wheel very center. thats your wheelbase.
Mar 15, 2009 | 2000 Chevrolet Venture
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
