Question about Kenmore Dryers
I have a Kenmore elite smartheat quietpak 9 drer that will not turn on (gets power ok) because the "check lint screen" light comes on when I try to start any cycle. I have completely blown out the hose allof the way to outside the house and flipped the circuit breaker many times. Is there a reset button or way to bypass that signal? Thanks - I am covered with nasty old lint and ready to bring out the axe.
  • garygosnell Oct 06, 2010
    I wrapped wire for good contact and taped the wires together after removing the fuse - did not help.
    Any other idea?
    Thanks
    Gary
    If I knew how to do all of that, I would not have needed basic help.
    I think I will check the function of my phone line and call Sears - thanks anyway.
    President:
  • 1,554 Answers
Such problem is commonly caused by a blown thermal fuse located on the blower housing. Disconnect power then remove the screws from the toe panel and remove the panel to expose the lint duct.
Remove the three screws from the lint duct and remove the duct.
The thermal fuse can now be bypassed or replaced if necessary.
Bypass the thermal fuse by disconnecting the wires and taping them together or jumping a wire between them and insulate properly. Once done, plug the dryer in then close and start it. The thermal fuse indeed blown and needs to be replaced along the exhaust thermistor if the dryer runs.
Posted on Oct 06, 2010
  • Jahn27
    Jahn27 Oct 06, 2010
    Check the resistance of the thermistor then refer to the thermistor resistance table below. Replace the thermistor if the resistance is not within the range given in the table. Test the continuity of the thermistor harness connector to the connector on the control board if the resistance is good. Replace the harness if found broken, if not, replace the control board.
  • Jahn27
    Jahn27 Oct 06, 2010
    Here's the Thermistor Resistance Table:
Kenmore Elite Smartheat Quietpak 9 Dryer won't turn on.....as if there is no power. After being unplugged for a while, it will run one cycle.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
I was given for free a kenmore he4 smartheat quietpak 9 dryer from a friend that was moving overseas. I have owned it for 1 week and all of a sudden it will not turn on. All the lights come on (red) and...
Have you tried unplugging the power cord yet? Leave it off for 2 minutes. It may reset the unit and solve your problem. If not, let us know and an expert from this category will try to help you further.
May 17, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite smartheat quietpak 9 model#110.85872401, it will not heat up just cold air. the air lint filter is clean.
make sure it is not set on air only,just went to a job and that's what it was lol.unplug dryer,take off bottom panel,on right side you'll see the heating element,pull off one of the wires and read out heater with a meter,if it's bad you'll need part number 3387747
Nov 07, 2009 | Kenmore Elite HE4 Electric Dryer
Control locked
Mine has an "auto dry" button. It says underneath, "Press & hold 3 seconds..." to unlock control. I did it, it worked.
Feb 07, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
1,048 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
