Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
Torque adj. will not turn - Black & Decker Pivot Plus Cordless Drill/Screwdriver
  • 15,935 Answers
The torque adjust detent is probably broken - or it's spring.
Truthfully - the repair will cost as much as a new unit.
Thanks!
Posted on Oct 06, 2010
Torque specs ford E350 tie rod ends and adj sleeves
Most years show 85 lb-ft for the ends and 41 lb-ft for the adjusters
Mar 21, 2015 | Ford Cars & Trucks
99kawasakiprarie300valveadjustment
MOVE EACH CYLINDER TO TOP DEAD CENTER OF COMPRESSION STROKE ( sorry caps on .) check that timing mark in timing cover hole is in line .remove adj cover per cylinder in alignment and adj valves according to mfg specs. to adj : under adj cover , loosen lock nut on top then loosen adj nut on btm @ top of valves . insert feeler gauge under rocker and adj ,this is tricky to say the least. usually takes several tries to get it right, keep trying the valves must be set right or major expenses can be expected to occur. intake and exhaust settings are different normally at least .005 .be sure to tighten locknut on top before checking if clearance is correct. holding the btm nut while turning the locking nut is the tricky part 4 me anyway. 2 valves per cyl. on most atv eng. adj all valves .start eng and listen to eng w/o reving up. any ticking noise and you get to start over. should be smooth idling and quiet. no popping or backfiring. smooth starting and off w/o run on. should not be performed unless you are familiar with the procedure. contact me or service center near you if not sure on procedure.correct adj. is slightly snug fit . valves making no noise when done .
Jul 12, 2014 | ATVs
Like another friend, my ryobi bts20 height adj crank is getting harder and harder to turn. I tried lubricating the adj screw from underneath.
Try to use a 'dry lubricant' available from an auto parts store so that gum doesn't build up and cause a hard turning screw on the adj. crank.
Dec 18, 2010 | Saws
I am looking for valve timing procedures and cyl. head torque spec for a 2001 m600
Your cams have a mark at the top, or the older style was a pin and a line. crank the engine over by hand to align the marks up, then peek through the site glass on the left side, It will be right on the mark. If it isn't, you wouldn't be running. The belts get replaced and the shims get replaced, that is your adjustment. I don't think there is any other adj that can be made. Your head torque settings are tricky, first, there are 3 stages of torque, 2 with a special wrench and the third with another special wrench or a home made adapter for your torque wrench, The books shows you how to make the wrench but it doesn't give me the numbers. Check out desmotimes.com, I know they only deal with 4 cam engines, but the wrenches and specs might be there. Hope this helps.
Jun 25, 2010 | 2001 Ducati Monster 600 - Dark - City -...
Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Nov 17, 2009 | Garden
Adj.clutch
those numbers have nothing to do with speed.
They are torque setting for the drill, so you don't overdrive the screw in....the smaller the number, the less torque.
Plz don't take you drill apart
Sep 26, 2009 | Drills
I m working on 1984 shovelhead. Just put in new clutchs New cable. It keeps comeing out of adj. In 1 or 2 miles. What is going on?
do u hav the ajust screw torqued properly-ur dealin with a vibratin animal--is cable within limits-hd repair manual r a must
Sep 13, 2009 | Harley Davidson FXDL Dyna Low Rider...
Carburator came lose from the head retighted it mess with jets
Turn the screws cw until they bottom then turn each out 1 and 1/4 turn. This should be enough to start engine. Then get max rpm by holding throttle down and adj. the H screw. Then adj the L screw until you get proper idle. You may then have to adj the H switch again to get max rpm.
Apr 10, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Jan 23, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. rroszman@yahoo.com
Dec 09, 2008 | 2001 Jeep Grand Cherokee
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
24 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
