Question about GE Dryers
Dryer Model #DWXR483EG1WW turns off mid cycle (timed dry) Dryer will restart after 10 min or so but will shut off again shortly. Timer is advancing. Dryer technician suggested replacing timer. Advice?
  • 49 Answers
It sounds like the technician is clueless on this one.
The first thing I would do is to remove the vent hose from the back of the dryer and try to run a cycle. It will heat up the room it's in but you will only need to do this once. If the dryer operates correctly you have a venting problem and need to clean the vent in your wall to make sure there are no obstructions and be careful not to kink the vent hose at all when it is reconnected.
If this does not fix your problem there is a chance that the motor is overheating and needs to be replaced. If you need further help just let me know.
Posted on Oct 06, 2010
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Runs for 15-20 min and shuts off when restarted it will do the same
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Oct 10, 2010 | Roper REX4634KQ Electric Dryer
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Automatic drying doesn't shut off
its the switch problem its got tripped internally so its not getting shut off.if the switch would have tripped to the opposite side that the dryer would have nit turned ON. so the switch needs to be opened the tripper needs to be replaced.easy job but very technical. thanks
Feb 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer only shuts off and restarts during cycle
Get a new timer. It is not that expensive and the wiring is fairly simple.
Jan 14, 2009 | Dryers
Dryers Logo
112 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
