Question about Philips Magnavox 27MS343S 27" TV
The DVD side works great, but the VCR is not working properly. After inserting a VHS tape into the VCR, it actually plays the tape for about 2-3 seconds, then stops, and shuts off. The VCR has only been used 1 time. I tried cleaning the VCR using a tape cleaner but it does the same thing after inserting that into the VCR...plays for 3 seconds, stops and shuts off. Any advise would be greatly appreciated. :)
  • krystal_droh Oct 06, 2010
    Idk why this has posted as a 27MS343S 27" TV, it's a Magnavox ZV420MW8 DVD Recorder/ VCR combo :|
    There isnt anything in the vcr, and everything else inside seems to look ok.
  • 65 Answers
This is a problem of the mechanism vcr. loock into the vcr because may be the kids put some objet inside vcr. To check also all the vcr belts.
Posted on Oct 06, 2010
  • Victor Oliver
    Victor Oliver Dec 28, 2013
    capstan motor problem
Samsung DVD-V3650 Combo Player ejects most videotapes without playing them
You can only compensate for minor scratches. As for the vcr side the rollers could be dirty or the brake worn out. The tensioner may be too sensitive as well. Basically the mechanism probably needs servicing.
Sep 06, 2016 | Samsung DVD-V3650 DVD Player/VCR
Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Feb 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
VCR
Hi dennis176,
Unfortunately, I am not aware of this kind of setup. This kind of solution would not be very efficient. For this to work there would need to be an insert to the VCR (similar to that which is used in a cassette player to convert CD audio) attached to a DVD player. Because you would require a device to play the DVD and send the video/audio to the insert (if it existed) it would actually be more efficient to simply connect the DVD player to the television. The reason inserts exist for cassette players is primarily that it prevents replacement of an entire car stereo system. This is not the case with a VCR. You may consider purchasing a DVD/VCR combo if you wish to maintain the ability to play VHS tapes. If you own a TV/VCR combo, your least expensive option would likely be to purchase a separate DVD player.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Emerson EWV603 VHS VCR
How To Burn a DVD from VHS tape
Insert the VHS tape. Do not press play. Insert a DVD RAM or DVD-R into the DVD side and press and hold DVD DUBBING, it should start playing the VHS immediately while recording on the DVD side.
Jun 03, 2008 | Panasonic DMR-E75V DVD Player/VCR
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Philips Magnavox 27MS343S 27" TV Logo
808 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
