Question about Husqvarna Viking 1
From BobSemmel@MSN.com Model C-20 After machine had sat idle for about four months, under its cover on a table, I tried to use it today, The LCD screen will not change. I have only a little experience with this machine which I purchased January 19, 2009, although I have been using other machines for many years. Can you help? Thanks.
  • 1 more comment
  • bobsemmel Oct 06, 2010
    This is a husqvarna viking C-20 sewing machine
    Thanks
  • bobsemmel Oct 08, 2010
    Yes, the LCD screen turns on but will not change no matter what buttons are pushed. Any ideas on what to do?
    Thank you. We will try unplugging the machine for 2 minutes as you suggest and then try it again. We will let you know the results.
    President:
  • 2,777 Answers
What is the make (manufacturer) of this machine? There are many devices with the model number C-20
Thanks, let me know and I can definitely help you Tim
Posted on Oct 06, 2010
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    I see, so on this machine the LCD comes on but will not change? It doesn't matter what you select as far as modes or other buttons?
    Tim
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    That is an indication that the machine has had a major internal hardware failure. About the only thing you can try is to unplug the machine for a good 2 minutes, and replug it in to the power.. Maybe even try another power outlet. Let me know if that doesn't make any difference..
    Tim
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    Sounds good, make sure to try another outlet as well just to rule out any possibilities of that.
    If that doesnt work it means the machine has hardware problems.. you will need to call contact a husqvarna person... I can find one for you, what is your zip code if need be?
    Tim
Will A 5530 free arm table fit my 534 Singer?
I would guess, probably not. (Unable to find any info on the 5530 table.) Wouldn't recommend buying it unless you can actually try it on your machine, the seller will guarantee that it will fit your machine, or the seller can provide complete free-arm insert measurements of the extension table and match them to your machine's free-arm measurement. Best bet would to get a guarantee to return for credit if it does not fit.
Singer machine models for Sewing Mates Tables Every Singer model will fit
Extension Tables SewingMachinesPlus com
Mar 11, 2016 | Sewing Machines
I have a Husqvarna classica 100 sewing machine that has sat unused for a few years. Now the stitich lenght will not adjust. It sews super tiny stitches no matter what the setting. I have tried to take...
With the small phillips screw under the handle removed, place your fingers on the ledge that the handle rests in while it's down, thumbs on the lower edge of the back cover below your fingers, pull slightly toward you and up at the same time. The cover needs to come out at the upper edge and then straight up to unhook from 3 screws that it hooks over.
Oct 30, 2011 | Husqvarna Viking 1
My Shark Euro-pro 8260 sewing machine smells like it's burning inside... what is causing this and how can I stop/fix this? It has sat for several months since I last used it... and I hardly ever use...
hi, the motor may be going out,,smell the motor to see if it smells like a pair of old dirty socks, if it does smell then it needs to be replaced.
if it's not the motor then it could be some type of electrical short,, it needs to be serviced by a sewing machine shop
when a sewing machine sits for months, it needs to be covered with some type of plastic cover where dust can't get in.
Sep 23, 2011 | Sewing Machines
I have a brand new reliable industrial sewing machine msk-8400bl18. i had a sewing machine guy out that showed us how to use machine, thread etc. about a month ago. everything went smooth and sewing...
hi.
given that the machine is only a month or so old, the best advice i can give you is to do nothing to the machine and call the sewing machine guy out to repair it for you. a brand new machine like this will be covered by the warranty. as long as you have actually switched the machine on properly, any faults are the responsibility of the supplier at this stage.
Jul 26, 2011 | Reliable MSK8400BL25 Mechanical Sewing...
I am having the hardest time ever trying to put this machine together and need someone to help me with step by step instructions. I am on a deadline and this needs to be finished today, classes start next...
hi there
if possibole contact me i can send instruction manual for this machine , also if you need more help please email me aabozid@homail.com or by MSN messengr .
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
Jan 22, 2011 | Juki DDL-8700
Screen turns on and flowers appear but will not continue
I had that problem last year. The repairman told me to make sure my sewing machine was on a very stable table, or it would move around & knock out the computer. The machine just barely moved, but that was too much. After I changed the table out that the machine sat on, it worked. Hope this helps.
Jan 31, 2009 | Singer Quantum XL-1000 Computerized Sewing...
White 1600
Maureen: If you want you can send me your address at goodtimetoni@msn,com I'll be more than happy to send you a copy of the manual for the White Speedylock Differential Model 1600. You can also call their toll free number at 1-800-331-3164 or go to www.whitesewing.com
Good luck and I hope this helps.
Toni
Nov 05, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
27 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
