Question about Samsung 24.6 Cu. Ft. 4-Door Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Ice maker is making a loud popping sound - Samsung 24.6 Cu. Ft. 4-Door Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Bgillespie
  • 89 Answers
SOURCE: Ice maker
Replace ice maker!
Posted on Dec 16, 2007
SOURCE: Ice maker grinding sound
I had the same and found the same solution. Chances are the problem will come back. Just over a week ago (when it was freezing cold in Florida) I took everything out of the fridge and freezer, unplugged it, even pointed a hair dryer in the ice unit. Once I was done it was completely defrosted and dry. I have not heard anything since - and I can sleep again ;-).
Posted on Nov 05, 2008
SOURCE: leaking water on floor only happens when making ice
I wonder if you just notice the noise now because the leak has you more aware? First things first. Lift up the arm on the ice maker (a few hours prior to attempting service) to stop it's operation. You need to roll the unit forward to give you access to the back. You'll see a plastic tube that runs from the bottom compartment (water valve) to the ice maker fill tube. Lower the arm of the ice maker and observe the plastic tube for the location of the leak. The most likely spot would be at the top. A hose clamp can be put on the fill tube after making sure the plastic supply tube is completely inserted into the fill tube. The fill tube is the piece that goes through the rear bulkhead and delivers the water to the icemaker. It may be neccessary to remove the icemaker to thaw out the fill tube using a hair dryer.
Posted on Apr 28, 2009
garing
  • 998 Answers
SOURCE: my fridge makes a loud popping noise. It does not
defrost heating coils breaking ice ( not to worry)
Posted on Aug 27, 2009
dmftrucker
  • 1922 Answers
SOURCE: My Maytag refrigerator makes a loud popping noise.
the popping noise you're talking about, could it just be your self-defroster in operation,sometimes if there a lot of ice and it operates a long time, there could be expansion noises,such as the refrigerator walls expanding/contracting from the heat of the defroster,if it's water you will hear a sizzling popping sound,nothing to fear dear
Posted on Dec 08, 2009
Every 20 seconds it makes a loud noise like a pump being activated
Sounds like the compressor trying to start. Is it making any ice?
Apr 05, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
My ice maker is making a loud noise
MOST HAVE A PLUG OUT OF THE I/MAKER,JUST BEHIND THE I/MAKER,JUST UNPLUG IT THERE..FRED
Feb 14, 2010 | Refrigerators
My Maytag refrigerator makes a loud popping noise. It woke me up at 1 am. Refridgerator is 10 years old no ice maker. The sound is pretty loud. Is this a bad sign? Is there any danger here? Should I be...
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Regular loud cracking and popping noises in Maytag bottom freezer. New how to resolve
this is unfortunatley a model problem
its the plastic changing temp
and expanding and contracting
Oct 03, 2009 | Maytag MFD2560HES Bottom Freezer French...
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Loud noise
Check the relay on the side of the compressor. Has a metal clip holding it to the compressor. Check with a volt meter and also check the compressor for voltage. no voltage or low at the compressor replace the relay. You can also take the relay off and shake it. If it makes a rattling sound replace it
Feb 14, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Samsung 24.6 Cu. Ft. 4-Door Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
192 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
