Laptop screen problem
My laptop is 18 months old. Recently when I open it to the normal position it goes black but when I lower it to 45 degrees it works perfectly. What can I do to sort it out or is it going to be an expensive repair?
  • hpisno1 May 28, 2008
    Thank you for your help. The image is always there but cannot be seen when the screen is fully open. Does this mean that it is a problem with the backlight? Can we just open the back of the laptop and look for obvious loose connections or is it better not to try ourselves?
    Scholar:
  • 125 Answers
You may have a problem with the flex connector that brings power and date from the body to the screen. Check the following:
1. When it goes black, can you tell if the backlight is still on? (It will be dim, but you can tell).
2. When it is dark, shine a bright light on the screen to see if the image is still there.
Also, check the button that is engaged when the screen is closed. This button simply turns the backlight off when you close the laptop and is usually located at the front or back of the body and may be a small pin, or an opening the screen hook will catch on. Press this button a few times under both conditions.
Either the screen data or backlight has a faulty connection and would require opening the laptop. The price of the repair depends if the wires or flex print are damaged, or the connector may just need to be reseated. You cannot simply tell without opening it.
Posted on May 28, 2008
  • Niels Boehme May 28, 2008
    It definately sounds like a loose connection with the backlight wires then. I do not know your skill level, so I cannot advise you about repairing it yourself. Try a google search on "disassemble abc" where abc = make and model of your laptop.
  • 3 Answers
Sounds like a loose connection, you will have to get the repair manual and try to fix it yourself if u don't want to take it to a shop.
My HP Pavillion G6 laptop screen goes black if not tilted in two certain positions
Sounds like the cable feeding the inverter is either faulty or has a bad connection. You will need to take the laptop to bits. See utube video.
http://www.youtube.com/watch?v=M7CEtfJtu_Y
Hope that helps.
Dec 29, 2013 | HP Pavilion Computers & Internet
My laptop can only be opened at a 45 degree position otherwise the screen is black in the 45 degree position the light and image is perfect.
You may have a faulty video cable that connects the screen to the motherboard or the video cable needs reseating to the motherboard.
Mar 12, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi there, I have a 80 series 1F87-361 thermostat. My indoor temperatures are consistently reading lower than what what I programmed. For example, I had it set for 22 degrees last night and when I woke up...
I understood from your statement that the sensor bulb is not in position. Check it should facing towards return air. And normally, if you set 20 degree, it will cut off at the end of 18 degree and cut in at the beginning of 22 degree.
Dec 05, 2010 | Heating & Cooling
Fujitsu Amilo Pi 1505 25-03-2010 I have a Fujitsu Amilo Pi 1505 Laptop. The screen goes black when viewed at normal angle, when lowered at 45 degrees it comes on. We opened bottom cover and removed the...
With so many questions that really relate to your dexterity and skills! Who can best answer your questions! Yea that person in the bathroom mirror is the only one that will show the fortitude and trail blaze the way. Then boast of their success!
Mar 25, 2010 | Fujitsu AMILO Pro V1000 Notebook
Very dull steering feel, wheel stays turned even as i slowly rev
Camber and caster settings are off. Have 4 wheel alignment done by a good shop and save your nice tires. Out of alignment will make steering feel heavy and wear tires fast!
Feb 06, 2010 | 2003 Nissan Maxima
DELL VOSTRO Display goes blank after it is more(than halfway open
You should be able to remove the LCD hingecover and reeseat the video cable. But hte issue may be a damaged cable going thru the hinge assembly which would require a replacement LCD.http://support.dell.com/support/edocs/systems/vos1500/en/sm/display.htm#wp1179838
Jun 04, 2009 | Dell Vostro 1500 Notebook
Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
Feb 15, 2009 | Acer Aspire 5315 Notebook
What tempratues should be set on a honywell 4 cycle thermost during the summer months
As a general rule set your t.sat 20 degrees below outside temp. Leave at this setting 30-45 minutes. Move down until comfortable no lower than 10 degrees below outside for 30-45 minutes. Unit should cycle normally. If it runs continuously then raise the t.stat 3 or 4 degrees up. The national average is 75-78. I usually keep mine set at 80 during the day here in Georgia and 74-78 at night...
Jul 03, 2008 | Honeywell Heating & Cooling
Screen problem
Perhaps your connections on the inside have come loose. It may warrant you take it to a specialist to check it over before it gets any worse. Some other person was on here some time ago who had a similar problem and all it was is the switch in the lid. Apparently they tinkered with it by just kept on pushing it back and forwards as if to continue to open it and it came right they tell me that they hardly used it thats why!.
Oct 02, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
252 people viewed this question
David Payne
David Payne
