Question about Zanussi ZDC37100W Electric Dryer
My zanussi dryer keeps turning off and the empty tank sign flashes even after emptying the tank
BingoDabbers
  • 102 Answers
SOURCE: ZDC5350W 'full tank' sensor
Look for the sensor in the tank. If it is a float sensor then check it is not stuck. If it is a probe then clean the insulator.
Posted on Oct 06, 2007
Timon90
  • 126 Answers
SOURCE: Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Posted on Jan 25, 2008
  • 1462 Answers
SOURCE: my zanussi TCS 675 EW
posibly a problem with the pump or a lint blockage in the pump chamber
Posted on Jun 19, 2008
  • 86 Answers
SOURCE: zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Posted on Feb 09, 2009
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
Not sure but try this..it workd with my Whirlpool dryer. Remove the condenser (clean it with water and a toothbrush too coz it will probably be clogged up) and pop a tea towel in the hole where the condenser was. Tip the dryer on its side and any trapped water will run out onto the tea towel or the floor OR the water reservoir where it should have gone in the first place......
Posted on Mar 13, 2009
Why does the condenser tank full light come on even though its empty
Hello, before call the specialized service try this:
Turn off and unplug the dryer from the main supply.
Open the main door of the dryer and with your hand attempt to move the drum up several times.
Aug 10, 2014 | Zanussi Dryers
Tip
OK I have now fixed my own problem with EDC 47130w dryer water tank problem.
The problem was the light to tell you to empty the tank keept comming on and the dryer would stop every 5- 10 mins and the tank always empty.It turned out to be lint blocking the tank fill area.
also some other problems with the tank and O"ring seals comming off.
I have made a video of my fix to share, here click the link to play the video.
I hope this may help. Please note this model looks the same as others so might be the same but different brand?.
on Nov 08, 2011 | Zanussi TC7114W Electric Dryer
Hey, i have a zanussi model zdc46130w. it stops drying after a few mins,and the "empty water tank" light flashes,even though the tank is empty?
the float down by the pump might be stuck......or the pump could be knackerd,................cheers
Jan 17, 2014 | Dryers
Beko condenser dryer
check dampness senser may still have lint trapped around it
also poss. stuck button on control board
Dec 06, 2013 | Dryers
I have a Zanussi Electrolux TC7103W condenser drier and for some reason the empty water light keeps coming on even though the reservoir is usually only half full. I have tried emptying it and tried un
Make sure lint build up is clear behind condenser
Sep 29, 2012 | Dryers
My zanussi dryer keeps stopping saying water needs emptied but it is always empty. The vent valve is always falling out is there supposed to be something to stop this?
I read the posts then checked my drier. I found the valve at the back of the water tank was blocked with fluff. So I tilted the dryer and unscrewed and removed the valve so I could remove the trapped fluff. Problem solved.:-)
Jan 16, 2012 | Zanussi Dryers
Zanussi tc7103w condenser dryer-water tank light keeps coming on when tank is empty or nearly empty-have found small plastic float and spring on floor behind dryer-where do they fit?
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Sep 23, 2010 | Dryers
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Indesit condensair dryer
I have had a similar problem, my wife tried drying clothes that were too wet, causing the machine to flood. Even though she emptied the tank, the empty water light was always on!!
What I did was take the electrical plug out and tip the machine to one side, you probably will find there will be a collection of water in the base, which will leak out. Once you think you emptied it, plug it back it back in and try it.
It worked for me!
Stooooman
Aug 15, 2008 | Zanussi TC180W Electric Portable Dryer
Hotpoint dryer TDC32
check the switch where you remove the tank towards he bottom
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Zanussi ZDC37100W Electric Dryer Logo
214 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
