Question about Philips GOGEAR SA6045 MP3 Player
Philips GoGear Glitch
I just bought a Philips GoGear 4GB MP3 Player and it can hold up to 900 songs. I added 511 songs so far and when I go to play the songs, after two or three songs it freezes. I have to press the restart/reset button in order for it to opperate back to normal. I then played some songs again and after two songs, it froze again. Is the MP3 player defective or could it be something to do with the music files that I downloaded onto it? They are all MP3 formated songs.
  • tkoryciak May 11, 2009
    Same here. It does the same thing for me.
  • 4 Answers
How many songs it can hold all depends on the size of the songs. You can downsize the song in windows media player by changing the quality. I have not been able to tell a big difference in the quality of the songs.
Posted on May 15, 2009
How to download music on to my mp3 player it is a phillips
Posted on Dec 24, 2008
  • 8,596 Answers
Make sure that there is available memory. If there is, then you will need to do a firmware upgrade and reload the songs onto the player. If you already have the latest firmware, then you will need to reformat the player either in Windows Media Player or the computer. If that fails, use the repair function in the Philips Device Manager.
-Tha Mp3 Doctor
Posted on May 28, 2008
Shuffle All Works only with 1st 250-300 odd mp3s from total 670
i dnt know how to remove my password so plz tell me how to remove my password
Apr 15, 2009 | Philips GoGear Flash MP3 Player
Mp3 4GB
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 03, 2009 | Philips GOGEAR SA6045 MP3 Player
Will not play all music in down load, says not correct format
You need to convert them to mp3 format for a mp3 player to recognize them.
www.dvdvideosoft.com
Feb 02, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips MP3 Go Gear
Does not play well with Windows Media Player 11.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Apr 25, 2008 | Philips GoGear SA178 MP3 Player
Philips HDD 6330/17, doesnt play music..
The rule for this device is first reset (hold power on/off and volume + simultaneously and continuosly while the player is turned on; reset works when the power turns off), and then Repair if that fails. The problem with Repair is that it deletes every file from the GoGear. Here are better instructions for repair than the manufacturer's:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
-Tha Mp3 Doctor
Jan 11, 2008 | Philips GoGear HDD6330 MP3 Player
Wont allow me to sync anymore songs but not full
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 22, 2007 | Philips GoGear SA178 MP3 Player
Phillips GoGear 4Gb - Can't sync songs onto player anymore.
Software can be found by going to:
www.usasupport.philips.com
Enter your model number
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "software and drivers"
-Tha Mp3 Doctor
Oct 31, 2007 | Philips GoGear SA178 MP3 Player
I synched my songs to my player, yet they won't play
-Tha Mp3 Doctor
Oct 18, 2007 | Philips PSA610 MP3 Player
Philips 1630/17 6gb mp3 player
-Tha Mp3 Doctor
Oct 09, 2007 | Philips HDD1630 MP3 Player
My philips 30gb wont play my songs!!!
-Tha Mp3 Doctor
Jun 20, 2007 | Philips HDD1630 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
247 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
