Question about YouTube Videos
How do you change ball joints on a 2000 lincoln ls
Has the car been through the safety recall for the lower ball joints? If not, you can probably get the manufacturer to pay for it by executing the recall. Check out Edmunds.com for the recall info.
Posted on Oct 10, 2010
  • 491 Answers
The dealer will tell you to relace the whole lower control arm, but MOOG has a replacement ball joint that can be pressed into you existing control arm
part number K500084 or K500085, depending on the year of your LS
Posted on Oct 07, 2010
What is the torque specs on ball joints on 2000 Lincoln LS
Ball joint-to-steering knuckle nut
Upper.....66
Lower.....110 to 148
Feb 20, 2015 | 2000 Lincoln LS
What is the torque spec on lower ball joints on 2000 Lincoln LS
111 lb ft. An important note on this model, there was a safety recall on these joints for being improperly torqued. Safety Recall 00S39
What does it mean replace upper and lower ball joints tie rods 2000 lincoln ls
they are front suspension pieces, and yes it is costly, but its not just the parts, there's labor also, and another mechanics opinion would be good.
Mar 10, 2013 | 2001 Lincoln LS
Is it difficult to change a ball joint on a 2004 Lincoln LS? What is involved?
Remove the steering knuckle
Steering knuckle off the veh,remove the
wheel hub & brg assy
2000 -2001 K500084
2002 -2005 K500085
Moog ---- Lower Ball Joint
(Problem Solver)
May 17, 2011 | 2004 Lincoln LS
Are the ball joints on a 2002 lincoln ls pressed in.....can i remove them myself and replace with out taking it to a machine shop or mechanic?
Moog --Problem Solver Bulletin Oct 2010
LOWER BALL JOINT-only
Lincoln LS 2000-2001 K500084
Lincoln LS 2002-2005 K50085
Remove Steering Knuckle from vehicle
Remove Wheel Hub Bearing Assy from Knuckle
R&R Ball Joint
You can do yourself,BUT may need to
have the joint pressed out and back in,
IF you can not borrow the tools or rent
I would take the knuckle to an auto parts
store that could do it for you
I would not pay someone to pull the knuckle
Do both sides
Also flush Power Steering,Drain Trans 2 or 3 times etc,
while your involved.
Dec 12, 2010 | 2002 Lincoln LS
Lower ball joint r/r how to
Remove the steering knuckle from vehicle
Remove the wheel hub and bearing assy
Remove the ball joint
Moog --Problem Solver Bulletin (Oct 2010 Brake and Front End, Publication)
Lincoln LS 2000-2001 Part # K500084
2002-2005 Part # K500085
Nov 05, 2010 | 2000 Lincoln LS
HOW TO PUT BOTTOM BALL JOINT
Requires 2 jacks, 1 under ball joint suspension, remove wheel. Remove ball joint nut, using a pickle fork tool separate wheel spindle from ball joint. With second jack carefully raise vehicle. Press out ball joint with tool and press in new and install in reverse instruction order.
Aug 10, 2010 | 2000 Lincoln LS
Replace the lower ball joint on a 2002 lincoln ls
Moog--Problem Solver Bulletin 2000-2005 Lincoln LS (Oct-Brake and Front End, publication)
2000-2001 K500084
2002-2005 K500085
You do not need to purchase steering knuckle from dealer.
Remove complete knuckle
Remove hub and bearing assy
Replace ball joint
Aug 10, 2010 | 2002 Lincoln LS
Replace whole knuckle or just replace the balljoints
the ball joints are in the control arms, they are serviced as a unit.
May 23, 2009 | 2000 Lincoln LS
YouTube Videos Logo
347 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
