Question about ASUS Eee PC 900HD Netbook
The spacebar on my asus eee pc won't space properly, you have to keep pressing to make a space. I made sure it was clean and it still has a problem.
  • bichonmama2 Oct 08, 2010
    Thank you for your response. The space bar lags a bit and sometimes works fine if you tap it twice. Frustrating sometimes. Sounds like a new keyboard might be the way I have to go. I have only had this Eee PC 1000HA for 14 months. To bad, because I really like it but don't have such favorable review anymore.....
  • ASUS Master
  • 13,433 Answers
Does the spacebar feel sluggish? - does it move like the other buttons do? It does sound a little bit like the keyboard would have a problem at that point of the board. You might need to replace the whole keyboard to get it working properly.
I would recommend that you get someone to look at the keyboard in person before you go ahead and replace the whole keyboard. It is very cheap for this laptop. But if its not a actual problem with the keyboard then the problem would remain unsolved.
Available at ebay : CLICK HERE FOR EBAY LISTING
How to replace the keyboard:
Replacing the keyboard on Asus EEE PC 900.
Time Required: 5 minutes or less.
Tools required:
  • Small Flat screwdriver
For parts check www.ebay.com
also www.pchub.com
Replacing the keyboard is very easy and simple on this laptop.
Disconnect the battery and the power cable.
Step 1. Begin by locating the small metal clips holding the keyboard in place on the top of the keyboard there are 4 or 5 of them.
Step 2. Use the small flat screwdriver to hold them in while you pull up the edge of the keyboard.
Step 3. Repeat step 2 for all the clips on the top until the keyboard becomes loose and you will see the keyboard connector below.
Step 4. Use the small flat screwdriver to carefully release the tabs holding the keyboard cable in place. Pull the cable out from the connector.
Step 5. Replace the keyboard, replace the connector back into the slot. Push the clips on the sides of the slot back in so that the cable is held in place.
Step 6. Put down the keyboard into its place, it should snap in, we are done.
Reconnect the battery and the power cable.
Test the keyboard by powering on the machine.
-- Let me know how you get along with it.
-Ekse
Posted on Oct 06, 2010
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
The Fn keys on my asus eee pc1015 suddenly won't work (only the brightness keys working). I got an error pop up that says something about the asus vibe that didn't work properly. what could be the...
stuck fn key ????
try turning the unit up side down and (lightly) tapping on the unit.. some thing could have go caught under the key ..
Hope this helps
Sep 20, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Eee pc r101 keyboard not working properly. Some of the keys won't type the correct letters and type the function letter or symbol instead or just random numbers. Also the touch pad and mouse click is...
The keyboard takes a lot of abuse and as durable as it is, they will eventually wear out. It is a very inexpensive part to replace and does not require a lot of skill. The fact that the touch pad is acting up could indicate that they are interconnected. I would replace both. The Touch pad is a more involved part to replace and I would suggest you get some help or pay to have it replaced.
You can order them off of sites like eBay, then watch a YouTube video on how to do it.
I punched in:
ASUS Eee keyboard and got several results like:
http://cgi.ebay.com/ASUS-EEEPC-EEE-PC-1001H-1001HA-1005HA-Keyboard-US-Black-/220660299406?pt=PCA_Mice_Trackballs&hash=item336060f68e
ASUS Eee touch pad:
http://cgi.ebay.com/Asus-EEE-PC-1005HAB-Palmrest-Touchpad-Cable-/330585537844?pt=LH_DefaultDomain_0&hash=item4cf86efd34
These are ramdomly selected:
Jul 24, 2011 | ASUS Eee PC 1000H Laptop
Space bar and certain letters not working keep pressing keys and other letters keep popping up
First Open your Control Panel and go to regional and language options
And Click on the languages tab as shown
Under text services and input languages click details
Make Sure Your Default Input Language is Set To English US (RED)
And your Installed Services looks like this (green)
Jun 06, 2011 | ASUS Eee PC 1000H Laptop
My spacebar on my ASUS K501 does not space unless you hit it towards the top.
TRY IT IF YOU HAVE IDEA TO OPEN THE LAPTOP
Turn your laptop off,Open keyboard only,see the keys under the space bar,clean it with Iso Profile(ip),sure it would work.
Feb 23, 2011 | ASUS K50IJD2 Notebook
Bios version for asus eee pc 10005ha touchpad screen freezes
Its not the Bos,just dont corrupt the boot procedure with unnecessary key presses.
Or reinstall factory settings properly--it has very little to do with the bios
Dec 18, 2009 | ASUS Eee PC 1000H Laptop
My asus eee pc900hd runs on (skip spaces) while
Well the easiest way to narrow the root of the problem would be to eliminate whether or not this is a software related problem.
So basically you will want to do a fresh install of the operating system. If this fixes the issue GREAT! if not your keyboard is more than likely experiencing a short.
Think of your keyboard as a grid of horizontal and vertical wires, when you press a key, that key makes 1 horizontal and one vertical wire connect this tells the computer which key is being pressed that it is also making a connection for the spacebar.
If you need more clarification or help feel free to leave additional comments but I would start with backing up any files you have and formatting the harddrive and reinstalling the operating system
Nov 20, 2009 | ASUS Eee PC 900HD Netbook
Some of my function key shortcuts have stopped working
go to asus website and click support. after that click download and find the ATK file...I tried both, but I believe the larger file is the one working
Oct 19, 2009 | ASUS Eee 4G Notebook
Can't get all avira files off of my asus eee
Download and run The Windows Installer CleanUp Utility found here
After its installed run the program
In the white box you will see list of programs installed
Click on Avira and then click remove.
Restart your computer
Mar 20, 2009 | ASUS Eee 4G Notebook
Webcam driver
Some times BIOS disable webcam after updating it.
To enable it do the followings:
1. Restart your Eee PC.
2. Press F2 while booting (to enter BIOS sittings)
3. Go to "advanced" tab (by pressing right arrow)
4. Select "Onboard Device Configuration" (by pressing down arrow)
5. From there you can find if "Onboard Camera" is enabled or not.
6. If not, just press enter to pick "Enabled"
I hope that would help :-)
Apr 23, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 900HD Netbook Logo
804 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
