Question about Garmin StreetPilot C330 GPS Receiver
GPS does not get charged
I am able to charge with my computer, but not with the power outlet in the car. I tried on my friend's car, which we know have a working power outlet and still does not charge it. Someone told me that it is either the cable or the power pinpoint inside the GPS.
  • Action Jacks May 31, 2008
    I am having the same problem with my Garmin StreetPilot c330. I know that it's not the fuse because I've checked it. I've also tried it it several other vehicles. It charges fine via the computer but not in any car.
  • cleverhan Jun 15, 2008
    I contacted the Garmin Support. They sent me a new mounting device, and that fixed the problem for me. Thanks to all those who responded.
Try replacing the fuse in the adapter...unscrew the part that goes in your cigarette lighter and there is a fuse in it. You can buy replacements at Wal-mart, Auto Zone, etc. 5 for $1.50 or less.
Posted on May 30, 2008
  • 174 Answers
Only use Garmin power cord. The voltage is regulated down from 12V (normal cigarette lighter voltage) down to 5v DC. Using the wrong power cord will fried your GPS.
Posted on May 29, 2008
    Problem Solver:
  • 5 Answers
Hi try a different dc adaptor thay are cheap enoughg
Posted on May 28, 2008
What do i do when my gps will charge in my friends car but not my own?
If it works with your charger in your friends car, I would car's outlet for power. Maybe the fuse to the outlet is blown. Hope this helps you.
Jan 15, 2011 | Garmin nuvi 250W GPS Receiver
Garmin 260w will not power up weve not used it in a while
Sounds like a bad or low battery. Do you have the Garminapproved charger / car charger?? You may have to send your GPS in for batteryreplacement or try this: There are three ways to charge the internal battery in yourautomotive GPS unit.1 Use the provided vehicle power cable that came with your GPSunit. The unit will charge while powered on and using the device as wellas when the GPS unit is powered off and plugged into a running vehicle. About 3hrs for a full charge. If the unit will not charge in the vehicle, check thefuse in the power cable for the unit and the power outlet in thevehicle. Use an AC power adaptor. Some units come with thispower cable to plug the GPS unit into a wall outlet allowing the GPS unit totake a charge. For units that do not come with this cable, one can bepurchased from Garmin's onlinestore. For most units, the final way of charging the battery is toplug the GPS into a powered on computer with a USB cable2. This method ofcharging will be a trickle charge and it may take longer (like a full day) thanthe other two options, however it will still charge the battery. A USBcable is provided with a few GPS models. For those that don't come with thiscable, one can either be ordered from the onlinestore or you can use a standard USB to mini-USB cable that fits the unitand plugs into your computer. 1 - Please note that temperature can play an effect on thecharging of a device. If the battery registers a temperature of 0°C and belowor 45°C and above (32°F and 113°F respectively) then it will not charge. Whenconnected to external power it will only be operating off of external power. 2 - The Quest® and Quest® 2 will not charge using a USBcable.
Dec 16, 2010 | Garmin nuvi 255W GPS Receiver
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 265 keeps shutting off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Dec 27, 2009 | Garmin Nuvi 265W GPS Receiver
Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Aug 06, 2009 | Garmin nuvi 265 Car GPS Receiver
MY GPS IS NOT CHARGING IN THE POWER OUTLET UNDER
Should say accessories or Power ! Also may be burnt out itself!! Also look for a burnt out fuse!!SWAMPRATT200!1aaaeee!!!!
Jul 21, 2009 | 2003 Dodge Caravan
Why doesn't my garmin nuvi 200 gps system charge?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your GPS in for battery replacement or try this:
Jun 30, 2009 | Garmin nuvi 200W GPS Receiver
Need to know how to charge garmin nuvi 255w using home wall charger.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
Jun 26, 2009 | Garmin nuvi 255W GPS Receiver
My garmin nuvi turns on for a second then turns back off whats wrong?
Jun 10, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi unit was indicatig battery charging when i . conneted to my computer. I removed and tried to turn this on ...it did not and then I have re-connected to my computer again and even tried to...
It take a day to charge the 260 WITH the correct cable for your computer as it will only trickle charge it.
Car charge does it in 2 - 3 hrs. If car is not charging it check the fuse in the end of the charger
And:
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Jan 04, 2009 | Garmin nuvi 260W GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
130 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
