Question about Panasonic CX-DP880 8-Disc CD Changer
Panasonic CX-DP880, will not load disk. disk tray jams, new unit
I have installed the CQ-8100U head unit on a 05 dodge ramand now about after year I am ready to install the CX-DP880 cd changer.
Question i have is the 12v continu power supply for the cd changer. Then manual says to connect to a continuous 12v supply, which I take as the battery (this is the yellow wire from the changer). Now on the cable that hooks to the head unit this power supply wire is only 12" long from the point to connect to the head unit. How do i connect to the battery if I only have 12" of wire.
I think i am missing something, maybe this wire connects to the head unit somehow, or maybe to a hot wire off the wire harness from the ram?
Comment by ubootwo, posted on May 01, 2008 Solution is to splice the yellow 12v supply from head unit and attach yellow from changer to it. note to remove battery cable as this is a continuous hot lead. Comment by ubootwo, posted on May 27, 2008 Now I got a new problem!, everything wired up correctly, disk tray was locked in and would not come out. I got it out but now all it says is error# 3 on dash unit.
Keep in mind was never used, brand spankin new.
Sounds like it may want to pick up disk but does not, keeps trying then shuts down.
Any tips?
Ubootwo
  • 7 more comments
  • ubootwo Jun 03, 2008
    Ok, I have already done the above, no help.
    What has happend is this:
    When i first got the unit the tray was not in the box loked in, so i did push it in. now thinking maybe i needed to have power to it to eject the tray i went ahead and wired everything up. then after all that it still would not eject. I was able to jimmy it so it would eject, so i thought ok, so i put in some cd's thinkin im good to go. but it now sounded like it wanted to pick up a disk and work but just made clicking noise and shuts down with an error 3 code. the reset does not help as well.
    Sorry I am not all that savy with this FIXya board yet.
    but anyhow, i am past the wiring stage, my problem is the tray will not eject, then i can get it to eject by prying a tad on the aide of the tray. once i got it out i put in cd's and it will click a few times then shut down and give a error code3.
    I suspect there is some type of miss alignment somewhere, but not sure.
    sorry, should have said i already tried unhooking the batt cable, turn key back in forth. no progress.
    yes i have made sure it was selected to mounted vert, there is screw slot to posit it vert or horiz, i have removed it from mounting tried vert, tried horiz.
    my thought is that the unit is somehow miss-aligned or jammed.
    the thing sounds like it wants to pick up a disk but just makes a few clicks then shuts down and gives the error.
    I have had the unit completely un-cased to ss if there is something i can see that would cause the problem but i could not see anything.
    i could take pics of the thing later and foward them to you but not sure you do that.
    I think maybe the worm gear has somehow miss-guided the disk selector mechanisam. im am not sure how to get it back aligned if this is the case.
    yes i loaded 8 cd's in the cd tray.
    and... they are in the correct oreintation
    Any other ideas? Nothing has worked yet!
  • ubootwo Jun 09, 2008
    Thank you all for your help, as othing seemed to work I have takin the unit to a repair outlet.
    Per Panasonic it has a 1 year warr, so they will repair for free.
    Regards,
    Steve
  • 3,037 Answers
Alright, it looks like you copied and pasted something and your first questions about the 12v wire not being long enough was answered and you just needed to splice the wire and add another wire to it which is correct but do it with the battery disconnected.
the error 3 is a jammed error, try resetting it by first removing the battery and if that doesn't work then try turning the key in the ignition back and forth quickly 10 times to reset the truck.
Let me know how this goes, also is the changer trying to open on its own (whirring of gears) or was it not doing anything?
Please update me after doing the above suggestions and let me know where we are at with this problem.
good luck
Posted on Jun 03, 2008
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Jun 03, 2008
    if you want to, take a few pictures of the problem areas that could be misaligned and send them to bestdarntootingood@yahoo.com and I will take a look. The good thing is that it is trying to open.
    So get me the best you can and I will see whats up
  • Benjamin Patri
    the tray is moving back and forth on it's track correctly?
  • Benjamin Patri
    Benjamin Patri Jun 04, 2008
    try pulling the tray in and out a few times and look for misalignment and make sure that it is riding correctly. Also move the laser back and forth a little, and also try turning separate gears to make sure everything is moving freely. Let me know how this goes
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    Please respond to my last comment and tell me what you find otherwise...
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 09, 2008
    sounds good, sorry I wasn't more help
    Sergeant:
    Champion:
  • 230 Answers
Though the cable is just 12" long ,just connect it by using extension box where we get options for plugging
    Brigadier General:
  • 3,614 Answers
What do you need now is a wiring diagram for that..
  • 4 more comments
  • micromaster
    micromaster Jun 03, 2008
    I got this for you, i hope this one will help you.. just take a look at this L I N K..
    Please post back again, and let me know if you still need assistance..
    Regards,
  • micromaster
    the yellow wire can connect directly to the battery, or connect it on the terminal / load switch which you can see other connections that has fuse.. or you can jumper / connect it on your CQ-8100U head unit line out to the battery.
  • micromaster
    - check again the harizontal / vertical you installed, its possible that there was a problem on the mounting of the unit..
  • micromaster
    the best thing you can is remove the unit from the its mounted position..
  • micromaster
    yah, that was possible.. a mechanical problem, bad timig due to bad operation..
    BTW.. does it has a CD inside..?
  • micromaster
    ***if my info/idea helps you, please kindly rate my solution.
POWERLESS /
Make sure you hooked up power ground and accessory. If you are connecting it just to make that it powers up, ut the yellow and red together and connect them to power at the battery. Connect the black to ground. Make sure the battery has power as well.
Aug 25, 2012 | Panasonic CQ-C8100U CD Player
Panasonic CQ-C9701U Head unit problem
is there a flexible cable that goes from the subpanel to the main motherboard? if so, the cable may be bad.
Jul 13, 2010 | Panasonic CQ-C9701U CD Player
How to connect a panasonic cx-dp880 cd changer to a cd receiver
My records do not indicate that they are compatible but are unclear, there may be some special connector used, none is listed however. Although if the cd changer is not a direct plug in, you can use an FM modulator. This device plugs in between (or wireless ones sit near) the antenna and radio transmiting a signal of it's own usually around 88.5 or so. Your cd changer or any other audio device plugs in to the modulator and it transmits the audio signal via an FM radio station. You then tune in your radio to the designated frequency and you're done. The only problem is weather or not your cd changer has a controller built in to facilitate this type of install.
-Dynami
Apr 06, 2009 | Panasonic CQ-RX400U Car CD/ MP3 Player
Connectiong ipod to panasoninc df200u
the df200u is a old unit it can not be done , you can hook up a cd changer to it thats all .. cd changer model cx-dp880
Feb 26, 2009 | Panasonic CQ-DF200U CD Player
Panasonic CD Changer with Pioneer reciever
Panasonic CD changers have a specific plug in that will not work with the Pioneer head unit. The Pioneer uses the IP-BUS plug. You will also not be able to convert the unit to work because the data between the two cannot be controlled and you won't have the ability to use the units together.
Sep 12, 2008 | Panasonic CX-DP801 8-Disc CD Changer
Panasonic CX-DP880 connector pins
what specific connector output/input pins..?
Aug 10, 2008 | Panasonic CX-DP880 8-Disc CD Changer
Panasonic CQ-VD7001U TOTALLY DEAD
Are the lights on at all on the head unit? Do you have the remote?
Nov 25, 2007 | Panasonic CQ-VD7001U Car DVD Player
Panasonic CX-DP880 8-Disc CD Changer Logo
177 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
