Question about Sharp Office Equipment & Supplies
Double fuser drive gear for sharp ar168 copier
  • 163 Answers
Can you explain what you are looking for?
Posted on May 30, 2008
Where is the fuser located on MXC 311
The fuser unit is located in the right hand side of the machine. If you open the right door, inside the upperpart of the machine you will see 2 grey handles, 1 towards the front of the machine, the other towards the rear. If you pull these handles out you can then remove the fuser unit. There are 3 known faults for loud fuser noises,1 is the fuser drive gear inside the machine strips the teeth on it, second, the main drive gear in the rear of the machine strips the teeth(usually caused by the 1st problem getting broken teeth stuck in the remaining teeth causing the drive motor to strip the main drive gear) & thirdly, the pressure release mechanism breaks on the fuser unit itself. If it is any or these then unfortunately you will need the assistance of a dealer to replace the damaged parts.
Hope this helps.
Dave.
Oct 13, 2014 | Sharp Office Equipment & Supplies
What do i do if i make photo copy and the gears sounds
The fuser gears brake alot on these because of the heat. Open the flip down cover on the fuser when it is cooled off and try rotating the roller by hand look into the right side to see that the gear is rotating with the roler if not your sharp dealers should be able to get you the part for around $22 and they could put it in for an hour of labor.
May 13, 2014 | Sharp AR-M205 Copier
When i close the back door it is making a loud noise. sharp al 1631
If it sounds like gears grinding it may be the fuser unit. The bushings and gears need replaced or new fuser unit.
Aug 31, 2010 | Sharp AL 1631 Copier
Have an AL-1000. got a crunching noise on start.error message flashes L4..motor drive error?
You most likely have a problem with your fuser rachet dive gear or it could be the upper fixing roller drive gear. I would first look to see if any of screws are lose that hold the fuser in. It could be just from wary and tary on the fuser or it could be that the lower fixing roller is damaged. If your copier has over 50k on it may just be easier to replace the whole fixing unit. Good Luck
Aug 10, 2009 | Sharp AL-1000 Copier
Need code to reset AR 168S copier
yes i know you press c photo c photo then all light is off press up and down arrow key
Jun 11, 2009 | Sharp AR-168S All-In-One Laser Printer
Hello everyone I have a sharp AL-1631 copier and when it starts there is a loud clacking sound coming from the rear drive side of unit can anyone aide me in a resolve?
There could be a few things wrong, but you most likely have a worn out fuser rachet gear, that drives the fusing unit or you may have a worn or broken fuser gear on the upper fixing roller. You can order the parts on line for about $20.00 + shipping. The only hard part is replacing the gears... The one on the Upper fixinfg roller is not that hard, but the rachet gear is kind of tricky... Alot has to come apart and then back togather. It is not hard, but you have to remember where the parts go back too. If you are not very comfortable with taking this apart, it may be a little to much to handel... It, could be just as simple as tighting the fuser screws??? Good Luck..
Apr 18, 2009 | Sharp AL 1631 Copier
"machine gun clicking" sound - fuser drive/motor gear area
Sometimes the clicking noise can come for the developer cartridge or the drum. you can carefully take them out and see if they turn freely.
Aug 12, 2008 | Sharp AR-M205 Copier
Jammed paper
where is it jamming ? pick up, on the side in the fuser where it gets hot???
Jul 17, 2008 | Sharp AL 1631 Copier
Sharp Copier AR-C270 Code Problem
sir there is no code of HS may be it is other code H4 or H2 so please write correct code
Oct 06, 2007 | Sharp AR-C270 Color Copier
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
