I am trying to use windows xp recovery console and it is askinf for adm password and there isn't one, oooo, or nothings works. Is there a way to clear it from wanting a password?
  • Rod Crutchfield Oct 06, 2010
    Had to close this question to start another one
  • 13,433 Answers
Just press enter on the password prompt, it should let you in, if not. then we need to reset the password.Here is a password reset disc that you can download and burn to a CD http://pogostick.net/~pnh/ntpasswd/
Thats a free program, a bit complex, but its free.You could also try this software I've personally not used it but its been recommended. http://www.recoveranypassword.com/recover/windows-password-recovery/
Let me know how you get along with them.
-Ekse
Posted on Oct 06, 2010
Forgot adm password
You're going to have to google 'password reset' and download an application, which is Unix based, which you then have to burn onto a cd, which you then boot up, and from which you can reset the password. You can't look at the existing password as it is scrambled, all you can do is reset it or remove it.
This is the only way.
Jun 11, 2012 | Toshiba Computers & Internet
How do I format my laptop using the recovery disk???
hi there, here's the step by step procedure for reformatting.
1. insert the recovery disk first to your cd rom
2. restart pc and keep on tapping the F12 key
3. once you are prompted for boot options select your cd/dvd rom drive
your computer will now boot up from your cd rom and will initialize the setup.
Apr 21, 2010 | Acer Aspire 4720 Notebook
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
XP corrupted. Safe Mode won't start. No admin pswrd for Recovery
Got a Virus? Format! It's a good occasion the delete the recovery console of Compaq HP computers. It's only a pain in the ***. Format all !
Apr 06, 2010 | Compaq Computers & Internet
A friend held down the pwr button after a windows update to restart the PC instead of doing a shutdown (he thought that's the way to do a restart) and now it BSODs on normal XP start and locks up mid...
The recovery console can only be used if you have a recovery disk that was supplied or if you made one.
This is not a repair option that will just repair the PC.
The admin password is the password you set, windows does not set any passwords, so if you did not set a password then just hit enter, but as I said you need the recovery disk.
If you can not get into safe mode or the PC does not have a option to enter system restore, which could be F8, then there are a few things you can try.
You can try the last known good configuration,
you can try the repair boot.
.Boot with XP CD or 6 floppy boot disk set. 2. Press R to load the Recovery Console.
3. Type bootcfg.
4. This should fix any boot.ini errors causing setup not to see the XP OS
install.
Your best bet is if you have the windows disk,is to reinstall windows, but you need to go to the maker of the computer or you need to go to the motherboard and get all the drivers for your system.
What happened was, when windows installs updates it is writing to the system, and it warns you not to shut down, and this can take up two a few hours, it could have been updating a service pack. The system is stuck in writing and you will have better luck just reinstalling when using windows xp.
Vista is eaiser to repair then xp.
Feb 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Can't repair bootsector in XP PRO
You can try this, with the pc running, open case,touch the metal case with one hand and the other hand unplug the drive. Now shut down
the system,unplug the system and hit the power button until the lights die. Plug in the drive and reboot the pc, go into bios and go to
boot. Check to see the drive is listed boot order. reboot and see if it boots.
If you can get into user account you can set admin password, then try restore cd then run fixmbr in dos.
If you can, get HDD Regenerator, and you can check the drive for errors, them run it again and repair them if possible.
But no, most of the time something causes the file to corrupt and lose boot not a bad sector on the hard drive.
Apr 07, 2009 | Microsoft Windows XP Professional SP2 for...
Hard drive failure
Hi, you have nothing to type there. You mean you have chosen the 1st section that opens recovery console,right? not that one. You should see the Terms of Agreement in your WinXP cd first, press F8. A section containing to install a Windows XP appears, Press Enter. Then that's the time it will search for your previous Win xp installation. In will then let you choose whether you will install a fresh copy of WinXP OR to Repair it. Choose the Repair. It will automatically repairs and format your Harddisk without deleting your files in it.  IF there's no Option to repair it, that's the time you will have to go to Recovery Console.
  • To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
    If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
If still you cannot get through to that, drop me a comment again and tell me what you have done. Feel free to ask me.
Dec 27, 2008 | Computers & Internet
My friend has a HP Pavilion 533w and when we turn it on it goes threw the loading screens and then to a black screen and nothing happens you can move the mouse and see the pointer but nothing happens...
It is possible that the file Lsass.exe has become damaged or is not properly linked to the other files in the security system. Reset this file by using the following steps:
1. Turn on the PC and press the F8 key repeatedly when the first screen appears.
The Windows advanced options menu appears.
2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
3. Select Microsoft Windows Recovery Console .
NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CDs, press the R key to open the Recovery Console.
NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
a. Turn on the PC, and press the F10 key repeatedly at the first screen.
b. At the Recovery screen, click Advanced Options .
c. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
5. At the command prompt, type the following: diskpart
6. Press Enter , do one the following:
  • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
  • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered.
Dec 26, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
Enter the Administrator Password
The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
    Type Y in response to this question and press Enter.
  4. The next prompt asks you to Enter Load Identifier:.
    This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  5. The final prompt asks you to Enter OS Load options:.
    Type /Fastdetect here and press Enter.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Need help
Sounds like a failing hard drive or corrupt file system.
Or possibly you have a non bootable disk in the floppy drive, assuming it has one as most laptops dont.
Is this Windows XP? If so, try booting from the XP cd. At the menu, choose R for recovery console.
In the recovery console, type in CHKDSK /R and let it run, it may take well over and hour to run, if it runs at all. If the recovery console is unable to load, or chkdsk wont run, you may have a failing hard drive.
Oct 23, 2007 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
