Question about Foxconn 865G7MF-SH Motherboard
Help need support cd for the foxconn 865g7mf-sh motherboard
Re-install built in VGA for foxconn 865g7mf-sh.. i need a support cd installer..
  • Anonymous Jan 03, 2009
    I have the same problem
Posted on Aug 31, 2008
Foxconn
865g7mf
865gv7mf
865pe7mf
Posted on Nov 28, 2008
  • 77 Answers
Here are the links to the drivers.
VGA
USB 2.0
LAN
Chipset
Audio
Posted on May 28, 2008
I need the driver of audio for pc 865 g7 mf - sh
Posted on Jan 28, 2012
Hola tengo un problema con una foxconn 865g7mf-sh, me bota un pantallazo azul diciendo que actualize los drivers de video o cambie el adaptador, lo hize pero ahora el error es con win32k.sys, me dijo en...
hola amigo tu puede solusionar todas problemas que tinga con tu ordinador con este programa desde a qui hay dos programa el1 es perfect optimezer ( ir a drivers back up ) el2 es ccleaner ir a tutorial videos
Jul 15, 2011 | Foxconn 865G7MF-SH Motherboard
865G7MF-SH on-board vga driver
Hi, you can download the driver here at foxconn:
http://www.foxconnsupport.com/download.aspx?models=en-us0000166&category=C000000001&series=en-us0000002&keywords=&sort=Drivers
Select vga driver and download.
The driver maybe needs to be unziped before installation.
Hope this will help you.
Apr 20, 2011 | Foxconn 865G7MF-SH Motherboard
I need vga drivers
You should be able to put the part number and other info in here:
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=865G7MF-SH&TypeID=en-us0000004
And find what you need.
Mar 09, 2011 | Foxconn 865G7MF-SH Motherboard
I have foxconn 865G7MF with on board graphic. After couple removing and attaching monitor without shutting off PC, the motherboard was loose video output. Rebooting dose not give any results, PC normally...
It's possible that the video processor has been damaged from ESD (electro Static Discharge) from the connecting and reconnecting while it was turned on. The first thing I would try is installing an expansion video card (like a PCI or AGP one) to see if that works. If it does, that was the issue
Feb 28, 2011 | Foxconn 865G7MF-SH Motherboard
Can you update vga intergrated graphics on Foxconn mobo 865G7 MF-SH?
Hi.
Yes you can, the board has an AGPx8 slot.
Please rate this solution if it was helpful. Thanks
Jan 31, 2010 | Foxconn 865G7MF-SH Motherboard
I would like to upgrade my hard disk capacity from 80 GB to higher ones. please suggest the list of compatible hard disk which i could connect to FOXCONN MOTHER BOARD MODEL 865G7MF-SH. Thanks.
It doesnt matter which hard drive you use there all compatible but make sure you check make connection they have either a sata or ide connection. Most people are using 160gb or higher, 1tb are very popular check with your local computer stores on the prices.
Jun 20, 2009 | Foxconn 865G7MF-SH Motherboard
Plz send me the link about the motherboard drivers of foxconn 865
You can download latest drivers for your motherboard here select -> motherboards -> socket 775 -> 865G/MF-SH -> sarch
Apr 02, 2009 | Foxconn 865G7MF-SH Motherboard
Upgrade vga version to 7
You can get all your drivers from Foxconn, click the link below.
Feel free to ask if you need more help.
Good Luck!
Have a great day.
Mar 14, 2008 | Foxconn 865G7MF-SH Motherboard
Foxconn 865G7MF-SH Motherboard Logo
2,634 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
