Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Where to get LCD Lamp?
Tantong, you said it is very easy to replace the lamp in this Gateway FPD1960 LCD display. Using a flashlight I can see images on the screen of my icons. Where can I get the lamp to replace the one that has apparently gone out in my display?
shanethepane-at-gmail dot com
  • 1 more comment
  • havanickel Jul 24, 2008
    My FPD1960 Monitor also died, I can't get a thing the screen is black and the power on button does not work. Tried rewiring, rebooting and all the fixes that I could possibly perform. Where can I purchase a power supply and how much do they cost. Thanks
  • YakAttack Aug 26, 2008
    azucho98, the power button on my monitor lights up and appears to function normally, do you still think it is more likely to be a power supply issue? And if so, do you know where to pick a power supply up?
  • Lou Ebert Jan 11, 2009
    YakAttack, Welcome to the club!! You are not the only one w/FPD1960 that has died prematurly. Gateway will probably be of no help unless you have extended warranty coverage. Have opened friends monitor and looked at the power supply board. Found some bad solder connections near output connectors for the backlight tubes(the things that make your screen bright) The solder connections have a frosted look to them rather than a bright shine as the aluminum side of a diet coke can. Possibly having them resoldered will correct the problem. What you are dealing with is something very similar to those new style light bulbs! COMPACT FLUORECENT BULBS. To light them up you need a lot of voltage, but only a tiny amount of current that is generated by what is called an 'electronic ballast' which uses solid state devices operating at high frequency >30khz to provide high voltage to light the tubes. 3 decades ago fluorescent lighting was done with large heavy step-up transformer-ballasts. two of them weigh about as much as your whole lcd monitor, and operated at 50-60hz, not 30000hz. Well, anyway, I wish you luck in geting it repaired. This model monitor was assembled in the far east and if a lawyer or attorney ever looks at the huge failure rate for all Gateway FPDs there could be some action. You may want to browse to 'electronicrepairguide.com or search for somebody called Justine Yong who has some pictures of pc boards from LCD monitors he has worked on. Just to see what is inside the plastic housing of your monitor. Good luck guy. You can reach me @ lmistyrel at aol.com if you need to cry on a shoulder or not. Louie north of Chicago.
    Problem Solver:
  • 9 Answers
Your problem may not be a lamp issue at all..it might be a power board problem.
Posted on Jun 09, 2008
Turned my gateway mx3414 laptop off, when I turned it back on the screen was black, turned off and restarted several times always just a black screen.
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 13, 2009 | Gateway Computers & Internet
Power stays on but screen goes black on my Gateway laptop.
If the laptop appears to boot up and the hard disk LED flashes then you have a backlight problem.
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
www.ladparts.net
Nov 22, 2009 | Gateway 450ROG Notebook
I have a gateway notebook,wen i loged it off 4rm the switch frequently. i did this consectively .the forth time it failed to display information on the screen.wen i put it on a mornitor it...
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
www.lcdparts.net
Oct 11, 2009 | Gateway MX3215 Notebook
The LCD screen on my Gateway M-6317 is dim. How
Press and hold the 'FN' key and tap the key that has the picture of a sun and an up arrow (or some other similar picture that dictates brightness - there should be two different keys that affect brightness one to increase and the other to decrease). Once you have the brightness set to your liking quit tapping the 'brightness' key and release the 'fn' key
Sep 29, 2009 | Gateway MX6447 Notebook
When I turn on my computer, the screen stays black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 09, 2009 | Gateway MX6956 Notebook
I have a Gateway M-6843 Notebook PC that won't power up.
Check out
www.lcdparts.net
Sep 06, 2009 | Gateway 7405GX Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Dell Inspiron B130 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Gateway 450sx4
Yes you should try ito adjust the brightness.
Can you see a slight image on the LCD, screen this indicates a backlight problem?
You can connect an external monitor to the video connector on the laptop, then boot it up and see if the is a display on the external monitor. You may have to press the blue Fn + one of the Function key so you can switch the video output to the external monitor. If you get an image on the external monitor then the video card is OK and the fault is with the LCD backlight. This could be a faulty inverter that supplies high voltage to the CCFL lamp or the CCFL lamp is faulty, 80% of the time it is the CCFL lamp that is faulty.
The inverter is easy to replace, the CCFL lamp requires a lot more work and requires soldering skills.
Go to www.lcdparts.net for parts and/or repair service and DIY info.
Mar 03, 2009 | Gateway 450SX4 Notebook
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
101 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
