How can recover my password on a Linux Fedora OS?
  • 11,800 Answers
Login as root and access that account - from there you can do whatever you want, including replacing the password.
Posted on Oct 06, 2010
Looking for drivers to use this monitor with Fedora 20 Linux OS
You don't need drivers. You need to adjust the resolution and refresh rate. If you plug in an old CRT monitor then Linux will probably boot and you can edit the conf file to change the settings. Most LCD monitors require 50-60Hz refresh rate.
May 05, 2014 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
WHAT IS LINUX?
Its all things good ;) the definition for it is: open-source version of the UNIX operating system.
So another words its free OS
But personally I like ubuntu way better thin fedora.
best of luck
Mar 04, 2011 | fedora Linux Operating System
How to install linux fedora 7, already i am using windows 7, now i want to use dual os's , please tell me how to install linux.
WARNING: I will not be responsible for any data loss that occurs. It is recommended to backup your hard disk to external media before commencing any of these operations. 1. Download and burn the Fedora LiveCD. It is recommended that you use the latest version, Fedora 14, instead of 7, but you can use Version 7 anyways. 2. Boot up with the Fedora LiveCD. Select Install. 3. Follow the instructions displayed onscreen. When you reach the partitioning screen, you will need to resize your Windows partition. Resize it to a reasonable size (1024MB =1GB). Leave at least 5GB for Fedora to install. 4. After resizing, select the "Use Free Disk Space" option, and continue installing. 5. Your system will be installed with Fedora and the GRUB bootloader. The GRUB bootloader will allow you to boot into both Windows and Fedora.
I hope this post helps you. I appreciate your vote very much!
Mar 03, 2011 | fedora Linux Operating System
My fedora linux PC after booting ,it asks for 'Give root password for maintenance". so what to do ? plz answer me
If I remember right,unless you set a password during installation,the password is root.
Bob
Aug 11, 2010 | fedora Linux Operating System
How to download and install apache on linux5
Hi Follow the below procedures.
How to install and start the Apache or httpd service under Linux
by Milind
Q. How do I install and start the Apache or httpd web server under Fedora core or Cent OS?
A. Apache HTTP Server is a free software/open source web server for Unix-like systems and other oses.
Apache features configurable error messages, DBMS-based authentication databases, and content negotiation. It is also supported by several graphical user interfaces (GUIs) which permit easier, more intuitive configuration of the server.
Use rpm command to install Apache under Linux. You can also use up2date or yum command to install the same.
Task: Install Apache/httpd under Fedroa Core/Cent OS Linux
Type the following command if you are using Fedora or Cent OS Linux:
# yum install httpd
Now, start the Apache/httpd
# chkconfig httpd on
# /etc/init.d/httpd start
Task: Install Apache/httpd under Red Hat Enterprise Linux
# up2date httpd
Start the Apache/httpd
Task: Debian Linux httpd/Apache installation
Use apt-get command:
# apt-get install apache2
# /etc/init.d/apache2 start
Task: Verify that port 80 is open
# netstat -tulpn | grep :80
You can also install httpd from CDROM with rpm command:
# rpm -ivh httpd*
Configuration
Your server is started but you need to configure and use Apache as per your requirement. /etc/httpd/conf/httpd.conf (RHEL/Cent OS/Fedora Core Linux) or /etc/apache2/httpd.conf (Debian / Ubuntu Linux) configuration file. Use text editor such as vi to edit file. This file is very well documented or read official Apache configuration documentation for more information.
Dec 30, 2009 | Red Hat Enterprise Linux ES 3 Standard...
I loaded fedora 10 on my dell inspiron 1545 and my blue tooth and wifi is no more working even with my network cable i can't browse the internet.
this is because Fedora and and other LINUX type of OS may not contain the drivers for your computer. You will need to download the driver from Fedora or Linux driver downloads and install them manually. This could be a pain.
Dec 18, 2009 | Dell Inspiron 1545 Notebook
Fixya Chat client for LINUX fedora 10
I actually don't know if one is available, but you could email General Support - support@fixya.com
I was wondering though if you can install under WINE in Fedora? I am used to Ubuntu, but have actually burned the Fedora10 .iso to a disk, but haven't played with it yet, so I don't know if you can install WINE to it, but I presume you can.
Maybe you could mount XP, grab the Chat Client Installer and see if you can run it using WINE?
I know it probably won't be listed as being supported by the repository, but it wouldn't hurt to try..
Good Luck
Chris (ziraffa)
Jan 14, 2009 | fedora Linux Operating System
Broadcom not detected by Fedora 8
i had the same problem and tryed lots of different os and the only one that picked it up was mepis 7
Oct 29, 2008 | Compaq Presario Notebook
About Linux fedora and XP
Without knowing more about your system, the key rule is to install XP first, then Fedora.
If that doesn't work then it's time to put more partitions on your hard drive, and install the 2 operating systems on different partitions, again, remembering that Windows XP has to be the first installed.
Mar 31, 2008 | Intel D102GGC2 Motherboard
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
