Question about Garden
Echo 200r gas string line trimmer. can I ajust the carb. and where? it will start after several pulls. and runs good after warmed up. but too many pulls
  • 12,061 Answers
Http://www.echo-usa.com/product.asp?Model=GT-200R&Category=TRIMMER
At the above link you will find your user manual, it show you what to do in the manual far better than one could explain, so please download it and follow the instructions. Also if you have any faulty parts to be replaced, they can be sourced from that site too.
Posted on Oct 06, 2010
Echo gt 200r
spring drive shaft broke
Apr 17, 2014 | Echo Garden
GT-200r trimmer caburator spoil
You can find replacement carburetor parts for string trimmers at PartsBuggy.com.
Sep 07, 2010 | Echo Rapid Loader, Trimmer Head
Have to start on starting fluid, won't stay running. have replaced gas line and filter and primer bulb. What next?
You will have to pull your head to see if the valves are seating. If the exhaust valve is not seating it will send blow back through the carb.
Jul 17, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Idles but will not stay running
This is nearly always caused by the muffler and muffler port being blocked by carbon not allowing the air to flow properly. Take the muffler off and see if this makes a difference. If so, then burn the carbon out of the muffler with a torch or throw it in an outside fire for awhile. Let it cool on it's own, do not use water as you will warp it and not get a good fit. Also take a knife and scrape the carbon out of the muffler port on the engine. Should solve your problem.
Jun 24, 2009 | Echo Rapid Loader, Trimmer Head
I have an echo mfg'd Echo GT2000 string trimmer with bent shaft. Gas not getting to spark plug. Could it be a bad Carb?
could be but lets try some other things first
On the carb. you have a primer bulb have you pushed that several times and is there gas in the bulb itself?
Are all of your fuel lines intact and not broken or brittle including the primer bulb?
Are you using fresh fuel mixture?
Be sure your stop and run switch is in the run position.
find your air filter and remove the filter itself
then you will be looking at the inlet side of the carb.opening and a orange choke shutter
Take a thimbles full of mixed fuel and pour directly into the carb opening with the choke off( turn trimmer on its side to do this)
now with everything (except for the filter) set to run try to start your trimmer 4 or 5 pulls
does it try to run? runs and shuts off? if so then you have carb. issues
which you can either replace or rebuild
sometimes if you do not want to tackle it yourself then it is less time consuming to replace it
but not cheaper.
hope this helps you some
Jun 13, 2009 | Echo Garden
Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
May 17, 2009 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
