Question about Lexmark 2381 Plus Matrix Printer
Printer Lexmark 2400 Forms Printer symbol issue
can someone explain to me, how it's possible that at random times, I get weird symbols on top of my chain paper. Sometimes all is ok, sometimes I get all sorts of weird symbols on top of the page.2 line with code language from DOS, spades, hearts , ç symbols , |, ....
Turning it out and back on solved the issue temporairy.
thanks already for hints...
  • 125 Answers
You may get this if you send the file in the wrong printer language language. For example, if you send a Postscript file to a PCL printer or sending graphics to a printer in text mode. Resetting the power clears the print buffer.
I am not sure if you mean you reset the power, then send the same file and it is ok? If so, check your cable first.
Is it on a parallel cable, serial, usb or network?
Posted on May 28, 2008
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
The page below is related to the 2480, as there is no listing at Lexmark for a 2400 (it is a series).
Based on the description you have provided, I would suggest several resolutions are possible. If the printer is not powered through a UPS (or other power surge protected power supply), it could very well be caused by power fluctuations. This seems particularly possible given that resetting power alleviates the issue.
It is also possible that there may be a driver issue, especially if this occurs more often with certain types of documents or in particular processes. The page above is for a specific model, and references drivers for that model.
If this is not the proper model, and you can not find the proper model, an online chat (also accessible through that page) could possibly be the quickest way to resolution. Please let us know if you need further help, as there are numerous other sources for drivers, e.g., otherwise thanks for rating FixYa!
My dell 1815dn when printing also prints random symbols on top of the document. It varies from one line of random symbols at the bottom of the page to about 4-5 lines of random symbols sometimes. I've...
This is most probably a corrupt driver so try the following:
1. Open Printers and Faxes on your computer and delete the driver for your printer. Then go to and open the drivers and downloads tab. Download and reinstall your printer. If the printer is still printing out symbols, it's most likely either a problem with your connection or with the printer's hardware.
2. Try using a different cable to connect the printer and computer. If you don't have one, connect and install the printer to another computer. If this stops the symbols then you will need to buy a new cable. If it does not then it is most likely a problem with the printer's hardware and you will need to get the printer serviced.
Thank you for using FixYa!
May 25, 2011 | Dell 1815dn All-In-One Laser Printer
Epson Stylus T10 printer prints out random symbols from PDF file
When you attempt to print, make sure you are using the correct printer. If you had an old printer before, its name will be still in the printers' list.
and unknowingly you may be trying to print with that printer. To check this:
Goto the File Menu -> select Print-> Highlight the printer you are currently using, and then Print.
I am pretty sure this will solveyour problem.
If it does, give a rating to this answer.
Have a good day.
Jan 06, 2010 | Epson Office Equipment & Supplies
My lexmarx printer has weird writing on the LCD screen i dont recognize it... how to reset the printer to factory defaults
How to Change the Display Language on a Lexmark X7310/X7350 ID: ENUS24252
  1. From the control panel, press Copy Mode.
  2. Press pattlnk_892006_1633-menu.gif.
  3. Press pattlnk_892006_1633-up.gif or pattlnk_892006_1634-down.gif repeatedly until pattlnk_892006_1636-across.gif appears next to 9.
  4. Press pattlnk_892006_1637-correct.gif. The right arrow symbol ( pattlnk_892006_1637-across.gif ) appears next to 1.
  5. Press pattlnk_892006_1638-correct.gif.
  6. Press pattlnk_892006_1638-up.gif or pattlnk_892006_1638-down.gif repeatedly until the language you require appears on the display.
  7. Press pattlnk_892006_1638-correct.gif to save the setting.
Jul 08, 2009 | Lexmark X7350 All-In-One Printer
you need to reset the counter. the new pcu should have come with instructions to do this. 1. Turn off the printer. 2. Open the front cover. 3. Press and hold the Continue button (Big silver button with Diamond shape symbol) and turn the printer on. 4. Hold the button down until the last light (error light) is on solid, release the button and close the front cover. 5. When the cover is closed, all the top 3 lights should be on solid. 6. Press the cancel button (triangle symbol) 4 times very slowly until you see the toner low light (second light from top) on solid. 7. Press the continue button and wait until you see the light sequence. 8. Press the cancel button and wait until you see the light sequence. 9. Finally power off the printer and power it back on to exit the configuration mode.
Jun 16, 2009 | Lexmark E250dn Laser Printer
Random Symbols on Pages I print
This sounds like a corrupt print driver. Try uninstalling and reinstalling the driver.
Apr 02, 2009 | Dell 1600n All-In-One Laser Printer
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server =;
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
Do not have installation cd rom for lexmark forms printer 2400 series
Manuals and User Guides for your printer can be found here.
Drivers for your printer can be downloaded from Lexmark here.
(There are several different models in the 2400 series. The above link is for the 2480. If your specific model is different, just search for that model in the Lexmark Search box on that page.)
*If you find the solution helpful, please rate it!*
May 02, 2008 | Office Equipment & Supplies
Lexmark 2381 Plus Matrix Printer Logo
855 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
