Question about Car Audio & Video
Wiring diagram for a jet sound eletronics model no. JS-214 griphic equalizer/ amplifier for car stereo
xxsodasipper
  • 93 Answers
SOURCE: car stereo wiring diagram
Well what kinda car is it and what year so I can help.
please email
xxsodasipperxx@yahoo.com
Posted on Dec 28, 2009
  • 239 Answers
SOURCE: what is the stereo wiring
1997 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
and im not sure if it has an amp but it has the triggger wire
pls rate
Posted on Aug 17, 2010
  • 20 Answers
SOURCE: Need diagram for sparkomatic equalizer
Not sure if they kept the old Sparkomatic diagrams or not but, the company Altec Lansing Technologies is/was the former Sparkomatic company. http://iratec.50megs.com/index.html is worth a shot if you have not yet solved your issue. They repair a lot of the old Altec equipment
Posted on Jan 30, 2011
  • 25 Answers
SOURCE: i have an urban audio
INPUT: Yellow (left front), violet (left neg), green (left rear), Blue (right rear), Brown (right neg), Gray (right front)
OUTPUT: Front Left pos (green/red) neg (green), Front Right pos (gray/red) neg (gray), Left Rear neg (brown) pos (brown/red), Right Rear neg (white) pos (white/red)
dfsanchez@yahoo.com
Posted on Apr 26, 2011
97F350diesel
  • 1326 Answers
SOURCE: i have a lear jet
The fuse is 60a...what color are the wires? Also is this a standard stereo for a car or is it an actual stereo for a Lear Jet (airplane)?? Just want to make sure I give you the correct info!
Posted on May 14, 2011
Need to connect a jet sound graphic equalizer JS-234 to a car stereo. The wires had folded stickers and some a gone. The colors of wires are red,black,gray,green.Only have 2 front speakers .
If it's only 4 wires, Red & black are typically power. red +12volts & black is ground. Gray would be one channel say right side and green would be left (example) you would ground the negative speaker lead on both sides. That is probably an old unit and make sure your car is negative ground. Some Ford & Nissan are positive grounded for some circuits which you may need to reverse the power connections. Make sure there is an in line fuse on the power wire just in case.
Feb 14, 2016 | Cars & Trucks
Need wire diagram for 1994 toyota windom
Whether your an expert Toyota Camry mobile electronics installer, Toyota Camry fanatic, or a novice Toyota Camry enthusiast with a 1994 Toyota Camry, a car stereo wiring diagram can save yourself a lot of time. Automotive wiring in a 1994 Toyota Camry vehicles are becoming increasing more difficult to identify due to the installation of more advanced factory oem electronics.
One of the most time consuming tasks with installing an after market car stereo, car radio, satellite radio, xm radio, car speakers, tweeters, car subwoofer, crossovers, audio equalizer, car amplifier, mobile amp, car amplifier, mp3 player, ipod or any car audio electronics is identifying the correct color car audio wires for your 1994 Toyota Camry.
The Modified Life staff has taken all its Toyota Camry car radio wiring diagrams, Toyota Camry car audio wiring diagrams, Toyota Camry car stereo wiring diagrams, Toyota Camry car radio wiring schematics, Toyota Camry car wiring diagrams and cataloged them online for use by our visitors for free. Our automotive wiring diagrams allow you to enjoy your new mobile electronics rather than spend countless hours trying to figure out which wires goes to which 1994 Toyota Camry part or component.
Jul 26, 2012 | Compaq Presario AMD V120, 2GB, 160GB HD,...
Jet sound equalizer js 214 wire color code
Black wire is ground, Red with 5a fuse is hot. Green/black is L Ground BTL, Grey /black is right ground BTL, the RCAs are left and right low level inputs. Then there is the 5 pin connector. It has a red wire for +12v, two black wires for input grounds, a green wire for left Hi input and a gray wire for right high input. If you install using traditional common ground high level, then you don't used the two BTL wires. Just connect the wires from your 5 pin connctor. If you use the low level RCAs for inputs, then you only need to connect the red and black from your 5 pin connector.(Plus the main red and black) Make sure the switched on the bottom of your EQ are set correctly. COM for common ground and LOW for RCA input or High for Green/Gray wire input. If you are using a floating ground the select BTL and connect the two BTL wires to the floating grounds of your stereo. There is also a line input adjuster so you can adjust your input sensitivity to match your reciever. I have the owners manual if you have any other questions.
Feb 01, 2012 | Car Audio & Video
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
Chrysler town and country wiring diagram
2002 Chrysler Town and Country Car Stereo
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Orange/Tan
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Gray/Green
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Green/Black
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Black
Right Rear Speaker Negative Wire (-): Gray/Pink
May 25, 2009 | 2002 Chrysler Town & Country
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Nov 14, 2008 | 2000 Ford Taurus
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
Hook up pioneer stereo amplifier model SA-1270
for audio system always you have left and right channels.
get the output (left&right) from tuner---go to equalizer input left&right.---from equalizer output go to amplifier inputs.and certainly from amplifier output to speaker.
Oct 15, 2007 | Audio Players & Recorders
Car Audio & Video Logo
194 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
