Question about Gateway FPD2275W LCD Monitor
Philips LCD Screen no display
Hi.. my lcd monitor no display completely blank just back light on wight screen
  • Anonymous Jun 04, 2008
    screen is blank no display or light
  • Rehan Khan Jun 17, 2008
    I need More Help component Level my computer is ok other moniter is working fin .
    Sergeant:
  • 458 Answers
Sounds like either your video is out on your computer or the monitor is bad. Does the monitor work on other computers? Will another monitor work on your computer? This is the only way to figure out if it is the monitor or the video card.
Posted on May 29, 2008
  • 1 more comment
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve the problem or figure out what was wrong?
    Can you please let me know if this solved your problem? You can also try another video card in your computer if the monitor worked on another computer.
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
    rehan,
    I never have gotten that far into a monitor repair. That almost takes a TV repair person. Did you take it apart and look for blown caps? I try my best to stay away from monitors, because they can kill you days after they are unplugged. Tread lightly inside one of those. I will adjust one on the inside and look for the obvious but that is as far as I go. I never have stated to anyone that I can repair monitors. I can diagnose whether it is monitor problems, or graphic cards and my help stops there. My work goes into the computer system. Sorry that I can't help you further than that. You might want to as a T.V. tech that question. My train stops here. I hope that you do not feel that this is inappropriate.
    Guest,
    You can read the same solution that I gave the other person. You can try it on another computer and try another video card in the system to see if the monitor is bad. If you need the computer help and figure out that the monitor is good let me know. I can help you more.
Hi, my hp dv2000 screen is blank when I turn it on. It hums and lights up like it's supposed to, but the screen is completely blank! What do I do?
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Nov 30, 2010 | HP Pavilion dv2000t Notebook
The screen on our philips 150C5BS has suddenly changed. The internet pages, etc no longer fill the display screen. How do i correct the screen display so it fills the complete screen
Hi ,
Right click on the desktop and go to properties.
Go to settings and change the scree resolution (reduce the current resolution what you see ) and say OK and check.
Jan 16, 2010 | Philips 150C4FS 15" LCD Monitor
No video image on LCD but OSD works
Sounds like you may have a bad video cale or a dmaged or bentpin in the connector, remove the cable from the monitor and look at the pins on the connector
Dec 14, 2009 | Philips 170S4FG 17" LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Monitor displays breifly then goes to blank screen
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Philips 170S4 white screen not display.
its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
Apr 03, 2008 | Gateway FPD2275W LCD Monitor
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Screen goes blank
Hi jkm007, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 12, 2006 | Videoseven V7 L19PS 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
