Question about LG CU500 Cellular Phone
Cell antenna for LG CU500
I want to add an antenna which will boost my reception.
What is your recommendation for type.
Where is the connector for the antenna? Is it same as earphone jack?
There is a small round rubber plug on the back of the phone above the battery, below and to the left of the camera lens that I believe is an antenna jack.
Posted on Jun 01, 2008
We can't get any reception at all with our LCD 23-231BB-G after moving to London. Using a One for All aerial SV9215 which had always been fine before. Re-tuning shows 0% signal strength. Any ideas? Tx
Yeah, you are getting lousy reception. If your antenna is directional re direct it to the direction of the stations you want to receive the most. Get an antenna amp to boost signals. Get a good directional antenna and mount as high as possible on mast for best signal reception. Make sure you have nada in the way of antenna and stations for best results.
Sep 03, 2017 | One For All Televison & Video
Some reception produces a crackle noise and stronger ones not. This is not a squelch issue. It is a different noise, like a short in the antenna or something.
Check the antenna PL259 connector. It sounds like the ground (shield of the coax) is not attached properly. I would recommend replacing it with a solder type connector and solder the shield to the outer ring of the connector and the center conductor to the tip of the connector. If the problem still exists, I would recommend trying a different antenna.
May 30, 2010 | Icom M302 VHF Radio
What fitting is the external antenna is it mmxc?
I hope everybody visiting this webpage will find this answer useful.
First of all, ignore the antenna connector recommended within the RAC Sat Nav 200 manual, it's wrong.
What you need is the :
GPS Antenna 1M Length MMCX with a
180 degrees straight connector.
Make sure it's a MMCX straight connector.
Plug in the antenna and within half a minute of typing your postcode destination into the Sat Nav the reception will have been picked up.
Hope this saves everybody a lot of hassle.
David Coggon - Author of Children's Book ` Jack's Crayons '
http://www.ahstockwell.co.uk
Aug 04, 2009 | SNK RAC SAT NAV 200 GPS Receiver
AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Jun 17, 2009 | Bose Wave Radio
Poor antenna reception
That's a problem with the digital broadcasting. Signal strength is critical, and the frequencies used are more directional. Some people are finding they get no reception at all. Your antenna may not need to be higher, but aimed in a different direction. Did you have a rotator installed as well? An outside antenna really should be pointed toward the station. You might also be able to add an amplifier to the antenna to boost the signal. But get a mast-mounted version that mounts right at the antenna, not the kind that goes at the TV set.
Apr 09, 2009 | Televison & Video
Radio/tuner reception
You will need to buy a signal amplifier antenna. One that doe not have to be connected to the Clock/Radio. It will provide the amplified signal and the radio antenna (the a/c line cord and the back of the clock/radio) will be able to pick up the signal from the amplified antenna.[http://www.radiolabs.com/products/antennas/am-antenna.php] this web link will show you one type of these antenna's. Copy the web link and paste it into the address bar in your browser. It will take you to the website. There maybe other types of these antenna's but this one had the best price. Call the store and talk to them before you buy the antenna to make sure it will work in your situation. I hope this information helps you with your antenna problems.
Feb 21, 2009 | Emerson Smartset Clock Radio
I have an unlocked LG Viewty (but still with Original T Mobile System on it) working with Fido. I didnt have any problems until the signal disappeared. The phone is working but there is no reception. I...
Try getting an antenna boost card they are compatible with all phones I believe there is one called cricket antenna boost they have them on ebay for like three dollars I havent tried one but its the only way that i know to boost your signal power
Sep 22, 2008 | Cell Phones
LG CU-500 Poor Reception
please clean your motherboard with accitone
and give a little bit of heat on motherboard
hope it works
for more information
you can mail me
raj_the_great2008@yahoo.com
thanks
Mar 22, 2008 | LG CU500 Cellular Phone
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
LG TU550 phone handsfree volume
VERY poor reception and battery goes flat in about 10 hours as looking for a signal. My wifes Nokia lasts a LOT longer and has much better reception
Dec 05, 2007 | LG CU500 Cellular Phone
LG CU500 Cellular Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
