Question about Refrigerators
MY WATER AND ICE TASTE DIRTY I HAVE A GE POFILE 25.2 CUBIC FT REFRIGERATOR MODEL NO. TFX25PR. IS THERE A WATER AND ICE FILTER IF SO WHERE IS IT LOCATED. QUENETTE QUENETTE1109@YAHOO.COM
SolutionGuy
  • 331 Answers
SOURCE: GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Posted on Jul 29, 2007
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
706Cajun
  • 34 Answers
SOURCE: Water from Ge profile refrigerator
The water filter for this refrigerator is optional. The GE part number is: WR97X0214, or one of the box stores also carries a universal filter. Just make sure it for a ¼ inch line. The water filter is located on the back side of your refrigerator, and will have to be pulled out from the wall. Use caution not to break the water line when pulling/rolling it out.
Posted on Apr 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: blocked defroster drain GE profile tfx25pr, tft25pr
Remove the freezer bins and shelves.
Remove the rear freezer panel.
The drain is on the bottom center of the freezer after the rear panel is removed.
Posted on May 25, 2009
lsteward68
  • 331 Answers
SOURCE: GE Fridge TFX25JRYDWW water tastes bad and ice is dirty
have you replaced the water filter?
Posted on Jun 15, 2009
Need the cubic ft for a year 2000 GE
Do you have a model number?
Jan 31, 2015 | Refrigerators
GE fridge 1999 model. water started tasting funny. found black stuff in a peice of ice. Water in rest of house seems fine.
Hello there,
When your water starts tasting funny and you can see some kind of particles in the ice, then it means the water filter is dirty and needs to be changed. Try to get the water filter replaced and the funny taste will stop.
If you are having some kind of lime taste or mud taste, or lime deposits or mineral deposit, is simply means you will have to replace the water line and reservior.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | Refrigerators
Model TFX25PR ; Does the ice cube maker require any lubrication ?
The type ice makers made for your model and other models require no lubrication and are one of the most used parts of your refrigerator especially if there is a large family and lots of ice used daily. They never seem to stop working while the average refrigerator last 15 to 20 years the average life of an ice maker is only 5 years. Even ice makers that have replaceable parts the repair parts are more expensive in most cases than complete replacement. Below is an example of an average ice maker that Whirlpool and Maytag uses that have the Teflon coating in the ice slots. Your model is for GE,=> Model WR30X10093 Ice Maker and has electronic controls and no replaceable parts. Thanks, Sea Breeze
Jun 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Why does the ice from ice maker have an awful smell and taste? Is there a filter that needs to be replaced?
i found that the previous homowners hooked the icemaker to soft water instead of hard water. Once I changed it to hard water, both ice cubes and water tasted fine.
Jul 09, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Ice maker is not working
Try this, pour tap water into ice maker and let freeze. If it dumps after freezing and does not refill with water it will point to water control valve. If it does nothing then the ice maker has the problem. I am really not sure what model or style of Pofile so I will need your model number to find part numbers and locations. Most profiles have electronic ice makers and if they go bad there are only a few fixes on some models depending on model number. Sea Breeze
Mar 19, 2010 | GE Profile Stainless Bottom-Freezer...
Do we need to replace a water filter on this GE model TFX25JRBA ?
I have a problem with my refrigerator , has a funky smell and when you taste the water is funky smell too, so waht is the problem the model is tfx25jrbbww serial vt231111.
Jul 05, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
