Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I was washing sheets and "sd" appeared. Now I had to unplug it to get it to stop running.
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Oct 06, 2010
SUD AND F-35 PROBLEM
SUD= The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future
As far as F35. Check your owners manual to see if its in there. Also if you remove the top lid ( a couple screws in back hold it in place) and check inside you will get the technician diag sheet which will have codes.
Jul 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code E27, ink absorber is full. Call service.
Follow these steps :
1. Unplug the power cord
2. Press and hold down the Stop / Reset.
3. Insert the power cable
4. Press and hold down the power button (the button Stop / Reset fixed in press)
5. When pressing the Power button, then release the button Stop / Reset.
6. Press the Stop / Reset 2 times then release the Power button.
"Wait until the digit 0 appears in the display"
7. Press the Stop / Reset 1 time.
8. Press the Power button 1 time, the printer will print a sheet of paper.
9. Press the Stop / Reset 2 times.
10. Press the Power button 1 time, the printer will mecetak a sheet of paper
11. Press the Stop / Reset 3 times.
12. Press the Power button 1 time. (No printing)
13. Press the Stop / Reset 4 times
14. Press the Power button 1 time rather long and loose (to turn off the printers).
"If the printer still can not get turned off, unplug the printer power."
15. Turn on the printer.
16. E27 error message is gone & the printer is running normally.
Oct 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
When I wash it does not drain and it says F12 and SD. I have to stop the cycle and press drain for the clothes to drain and the cycles do not complete.
Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds 8 minutes and the water valves turn off. After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the F21 error code will be displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the drain hose and make sure it is not plugged or kinked. If the drain hose if fine then unplug the washer and check the electrical connections at the pump and make sure the pump is running. Check the drain pump filter for foreign objects. To access the drain pump and filter remove the front kick panel and trace the drain hose to the bottom of the washer, drain pump would be located there. If you are not able to access it, then replace the back panel as well. Plug in washer or reconnect power. If the issue is still not resolved then you would need to replace the drain pump. Hope this helps...
Daniel
Sep 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer does not seem to be going through the rinse cycle.It doesnt drain all wash water out. When it FINALLY stops the letters Sd are lit............WHY
overdose of detergent during wash cycle try running the unit in a rinse spin here is also a tehnical sheet that u can get from this site as a pdf sd stands or suds lock http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
hope this helps
Jul 15, 2010 | Kenmore HE2 Plus Front Load Washer
Washer stops, shows SD on display then F- alternate with 21
A display number preceded by the letter "F" is an error code. The error needs to be resolved before the washer will resume normal operation.
"F21" is a Long Drain error code. This is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" or "SD" error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are both very simple repairs that you can perform yourself without the assistance of a repairman.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Jun 07, 2010 | Kenmore HE2 Plus Front Load Washer
My washer won't complete it's cycle.It appears to be locked up in the computer system. Any suggestions? I have unplugged and reconnected.
Hi, remove the panel under the door. Behind this panel you will find the tech sheet. Once you have this tech sheet it will give you instructions on running the diagnostic cycle. Run the diagnostic cycle which will then tell you what is wrong with the machine and the corrective action needed. If you have any additional questions please feel free to comment. Mike
Dec 19, 2009 | GE Washing Machines
What does F- indicate?
The SD code, is a sudsing code. If you are using the appropriate amount of soap and HE soap, it could be a communication error with the sensor and the CCU (the main control board). If you take off the panel on the bottom of the front (3 screws on the bottom hold it on). Once you get in, there is a plastic pouch on the right hand side there is a tech sheet that will have a list of all the error codes, and what to check.
Good luck
Dec 23, 2008 | Kenmore 43142 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
228 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
