Question about GE Refrigerators
I have a GE ESS25LGNA BB. We came home to water in front of refrig & neither side cold. Lights work, Freezer fan on, compressor fan is on. Checked back of circuit board and found no burn marks or abnormalities.
  • 1 more comment
  • troy695 Oct 06, 2010
    Determined the water was from melting since the temperature has changed. Already checked for leaks. Help?
    I pulled the coil cover off & checked coils: somewhat cool, no moisture on them, fan in freezer above coils running constantly. Sometimes the fan shuts off when the doors are opened, other times it stays on.Any other ideas?
    Thank you for the repsonse. When we came home there was no frost and the refrigerator side was warming up, the freezer was not cold at all. After checking the coils & pan, there looks to be no leak. The water looks to be from the ice melting since there was still water in the ice bin. After cleaning out, the lights work, fan in freezer side runs and I can feel the air it is pushing in the refrigerator side but it is not cold. The rear fan on the bottom right side is also working. How do I verify if the compressor is bad? Another note: I replaced the ice maker 2 months ago and it has worked fine since, before the ice maker went out, the refrigerator was freezing items even at temperature level 5. Any thoughts would be great, thanks for your help.
    Genius:
  • 1,456 Answers
Hello there
Frost free refrigerator models utilize a drain to take the water melted off the coils to the evaporator pan. This pan collects the water in the bottom of the unit and uses the heat of the compressor to increase the evaporation rate. If this drain becomes clogged with ice or debris it will back-up and eventually over flow. This overflow usually collects in the bottom of the fresh food compartment below but can also leak onto the floor.
To correct the problem, you must locate the drain and inspect it for blockage. Often, you'll find it frozen, but it's usually always solid debris blocking the flow of the water that's CAUSING it to freeze: and that must be removed from the drain or it WILL happen again.
After unplugging the fridge from the AC power, go ahead and pull the unit out where you can access the back. This is also a GREAT opportunity to clean dust off of the condenser coils and compressor, which will GREATLY lower your energy costs! (Use a Vacuum with brush attachment)
Depending on the model of refrigerator in question, the drain port can be located in several places. The most likely location is just under the freezer, which is actually the top of the fresh food compartment: The tube usually comes out there, and down the outside of the refrigerator; (On Back) However, it can also be under the coils behind the false back and/or side walls. At any rate, when looking for it, keep in mind that its' sole function is to drain water away from the evaporator coils when the unit is defrosting itself; Therefore, it's almost ALWAYS just under the freezer at the end of a "channel" that directs all of the water into it.
Cleaning the Drain... Depends on what's causing the clog.
If it's iced up, the quickest way to thaw it is with a hairdryer. It takes just a minute with the hairdryer set on max.
Before you get happy and close everything up though, ALWAYS check the tube for debris.
About 95% of the time, I've found something in a frozen drain line. Remember: It wouldn't have been frozen in the first place if the water had been able to drain off!
After checking the pan under the freezer for debris in the pan and exit hole, you'll need to check the tube itself. The best test is just to blow through it like you would a straw. If it's clogged, you'll feel some resistance.
To clear a clogged pipe: There are numerous ways, but the most efficient is to use a can of electronics duster. (ONLY the kind that comes with a nozzle extension tube) WITH A PAIR OF CLOTH OR LEATHER WORK GLOVES ON BOTH HANDS!: Stick the nozzle extension down into the drain tube. Wrap one hand around the top of the tube and the nozzle to form as tight a seal as you can, and press the trigger. The clog should be blown right out: if not repeat as necessary. Reconnect it all, then pour a little water through it and check for leaks. Hope this helps!
Posted on Oct 06, 2010
  • GE Master
  • 17,130 Answers
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
water in front of the door can be the overflow from the defrost tray, a leak from the overflow or drain pipe.
Please check this out and comment.
The advice given is for help asked to us .You must attempt to do it yourself only if you
are technically/logically able, especially when dealing with delicate devices, damaging
while trying to open, Probing electrical/electronic circuits with high voltage or delicate
components. Since the advice given by me is with the inputs provided and not based
on a visual inspection, there can be further reviews required in some cases.
  • 857 Answers
Analyzing the likely source
Step 1
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
Fixing a drip-pan problem
Step 1
Pull off the grill that runs along the bottom of your refrigerator.
Step 2
Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode.
Step 3
Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer.
Step 4
If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill.
Fixing a clogged defrost drain
Step 1
Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment.
Step 2
Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole.
Step 3
Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan.
Fixing a leaky ice maker
Step 1
Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.)
Step 2
Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker.
Step 3
If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it.
Step 4
Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement.
Step 5
Remove the faulty line and take it to a hardware store to get an exact replacement.
Step 6
Install the new line, tighten the connections with the adjustable wrench and turn the water back on.
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a GE refrig. model GTS22ZCMARCC. The evaporator fan has been pulsing up and down forever. Then the freezer stopped getting cold and the refrig. part was not as cold. I check the evaporator fan...
it's the board,also change out the sensor that's on top of the coil,it looks like a white bullet,the part number for the temp. sensor is wr55x10025 and the board is WR55X10942.everything runs through the board,i've seen when you call for water the compressor stops or the water doesn't dispense,or the fan pulsates like you have.let me know how you make out
Oct 21, 2010 | GE GTS18SHPBS Top Freezer Refrigerator
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
MY REFRIGERATOR MODEL#GSS20IETA BB DOES NOT GET COLD IN THE REFRIGEATOR SIDE . WHAT COULD THIS BE?
open the freezer and listen for the evaporator fan motor, if you can't hear it running then you need to replace it. it pushes the cold air from the freezer into the fridge to keep it cold.
Nov 13, 2009 | GE Refrigerators
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Neither Freezer nor refrig is cooling
Pull the compressor side cover off. Pry off the square box. This is your compressor start relay. Check for continuity. It's probably blown. If ok check for voltage to the compressor.
Jun 07, 2007 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
