Question about Husqvarna 28cc Gas Line Trimmer
HUSQVARNA 125L/LDTHE TRIMMER WILL NOT CARRY A WORK LOAD.I PUT IN A NEW CARB KIT
  • webstar40 Oct 06, 2010
    I HAVE REPLACED EVERY THING IN THE FUEL SYSTEM SXCEPT THE CARB BODY,IT RUNS GOOD BUT WILL NOT CARRY A LOAD VERYLONG BEFORE IT STARTS TO DIE. IT ACTS LIKE FUEL STARVATION.I CAN PUMP THE THROTTLE AND IT WILL TRY TO GO BUT DIES EVENTUALLY.
  • webstar40 Oct 07, 2010
    I still don't know how to fix my problem. It is very hard to start also.
  • 2,973 Answers
If there is enough fuel coming and a goos blueish spark on the spark plugs then it will start. Please ensure that the fuel is flowing fully into the carb. Its not running under load means that it is not getting enough fuel when under load. The fuel supply is just about sufficient for it to idle. So, make sure the fuel is reaching the carb in copious quantity.
Posted on Oct 06, 2010
  • 652 Answers
Buy a new Homelite you can get one for under a hundred dollars at home depo. This will help out and the parts for yours to fix would be about the same. Sounds like there is a problem with power, could be the cable drive is malfunctioning.http://www.homelite.com/
Husqvarna 125l carb problems
Check the fuel lines. Ethanol in the gas swells the old type fuel lines.
Jul 17, 2014 | Garden
I have a Husqvarna 125L weedeater, New Fuel, has spark but will not start. Pulling the starter rope makes me feel that either I have a compression problem or a clutch problem it is just to easy to pull. I...
Hi there. Firstly remove the end with the starter cord and make sure the fly wheel is opening when you pull the cord. If not lubricate it until it frees.If it is working then it could be just the carb gaskets need replacing or the worst case is that the piston is broke and may need sorting.
Oct 05, 2013 | Husqvarna Forest & Garden 125l 18" Gas...
Is there a brush cutter kit for a 125L Husqvarna grass trimmer?
Brushcutter kits should fit this model however it is quite a small engin within the range so may not be advised and it could put extra load on the engine and drive shafts
Nov 29, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna 125L quit running, it runs then shuts off
You likely need to replace the muffler,this is a common problem and if the engine can't get rid of the exhaust it also will not take in more fuel,happens a lot with anything with a spark arrester in the muffler.
Apr 18, 2010 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
May 17, 2009 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 28cc Gas Line Trimmer Logo
116 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
