Question about Danby DBC514BLS Silhouette Beverage Centre
My danby beverage centre does not cool anymore 3 years old. compressor is hot. fan sounds and appears to work well all coils are clean.
  • Danby Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ,.,
Posted on Oct 08, 2010
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Aug 08, 2015 | Danby Silhouette Series DBC514BLS 5.3 cu...
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
The compressor on my Danby dehumidifier turns on for a few seconds, very weakly, and quickly cuts out. The fan and control panel are all working properly. The humidity is high enough for it to turn on...
Sounds like you've lost a lot of freon. Find the pump on your unit. Be careful, but after running it a while, touch the tube somewhere between the pump and cooling coils. If it is not hot then you have lost fluid. What happens is under normal working conditions the compressor would compress the freon making it hot, which then gets cooled by the radiator coils. In your case, there isn't enough fluid to compress to make it hot. Unfortunately, you need to have it refilled by a repair shop. Try your local A/C or HVAC shop. Don't be surprised if they can't refill with freon as it's bad for the ozone and being phased out.
May 04, 2011 | Danby DDR586R Dehumidifier
Our danby dwc 283bls is not cooling. The motor
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Nov 17, 2009 | Beverage-Air MT27 Beverage Cooler...
Doesn't cool and i am assuming that means the condensor. How much to fix. it is two years old but with very little use , looks brand new.
clean coils front and back....clean drain oil fan motor...take cover off relay...clean plugs and pins( from oxide)...if it starts hard get a har d start kit for compressor
Aug 28, 2009 | Danby Silhouette DWC512BL Wine Cooler
Sanyo sr-1013w not cooling
sounds like it has a refrigerant leak somewhere in the unit.
Feb 20, 2009 | Sanyo BC-1206 Commercial Beverage...
Beverage Air ST58N Not cooling
Compressor is cycling on the overload protector. Cause could be a bad starting relay but is more than likely the compressor is bad.
Jun 11, 2008 | Carrier ST58N
Danby DBC514BLS Silhouette Beverage Centre Logo
725 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
