Question about HP LaserJet 1020 Printer
I need to install the driver once and again almost every 2 days, seems like something is not working well... don't know if the problem is the printer, the laptop or where
  • HP Master
  • 7,733 Answers
The best way and time saving is to Unistall the printer and install back.
Posted on Oct 06, 2010
This morning i went to crank my truck a 2006 Ford F150 and the battery was dead. After I got out to pop the hood I heard a strange clicking sound coming from in between the cab and bed - that is where it...
Pure SWAG on my part, but the only 2 things I can think of on the back cab wall are the power slider motor ( if a rear power slider is installed ) or the VSM ( Vehicle Security Module, called a Body Security module on 04-05 MY ).
should not be clicking, maybe an issue with maybe the ground to the VSM ?
You would need to remove the seat back if it is a SuperCrew or SuperCab, to get to the VSM to check the ground, and if any of the pins are discolored in the connectors ( remove and check ):
These are the pictures from when I installed the heated seats in my SuperCrew
Where the screw driver goes into release the clip.
Close up of what you are shooting for when the seat is installed, the screw driver needs to go through that openeing to trigger the clip.
The trigger you need to press to release the seat back. Best once you get 1 side released, stick something under it so it does not click back into place, I used a 2x4 in a sock to slide between the seat back and bottom.
Sep 19, 2011 | 2006 Ford F-150
Ethernet (wired) connection to computer works but "wireless" light does not come on and my laptop cannot locate a wireless access point or network device. It has worked in the past but after...
You will need to get a hold of att. They will need to have you unplug the 2wire and then reconnect. They will need to reset the gateway from their end. good Luck.
Sep 07, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Don't know how to get sound to work after reformatting
Hi kra02,
In order to get your sound to work again you will need to download and install your audio driver on the machine again.
You mentioned that you have a Compaq, you can go online to the Compaq website to get your Audio driver and probably the other drivers for your machine since you reformatted then you need to install all drivers needed for your Compaq.
Check in device manager under control panel to see which drivers needs to be installed, then you can download from the Compaq site to have your machine running fine again.
Drivers that you probably will need to download is the Chipset Driver, Video Driver, Audio Driver, LAN or Ethernet Driver, these are drivers that are most important.
I hope this help.
Have a nice day,
mvincentc
Jun 05, 2011 | Compaq Audio card Sound Card
Something happens, don't know what, but something did :D audio, recording and playback devices cant be found on my computer :((( a few days before this work ok, but it look like i make wrong something...
I think you have unconciously uninstalled your sound card. Try installing your sound card again and see what happens. i think after installing the drivers of your audio card it should be back again..
If this answer helped you please like/rate it.. Thanks
Jun 01, 2011 | Acer (54.AA806.001) Sound Card
Ethernet card does not show up on device manager after upgrade from windows 98 to 2000pro. IBM thimkpad A20
Hi Dear,
After an upgrade, you need to re-install the drivers of the Ethernet card once again.
please re-install the drivers once again. This should solve your issues.
If this solution was helpful to you, please let us know about it. And if you need further information please do write to us. We will be pleased to serve you once again.
Have a nice day, :)
Nov 06, 2009 | IBM ThinkPad A20M Notebook
How can i download a motorola l6 driver?
go here
http://www.nodevice.com/driver/L6/get39380.html
Jul 23, 2009 | Motorola Mobility L6 Cellular Phone
The speakers stopped working it says there's no driver 1st it happened i reinstalled the driver and it worked fine all day then i had shut the computer down and hours later when i turned it on it once...
Hi...
Have you ever installed a "Deep Freeze" software... if so, then you have to disable it and restart, then install the sound driver. Then enable it back on...
Deep Freeze, it will not allow any installation or saving when this is enabled. See also other similar programs that do this function.
For what I know anything installed there on the system stays even if you restart it, you agree right. But Deep Freeze and other similar programs will not permit installation, update, virus infection, even saving files to the protected drive (ex. drive C).
Let me know if still does not work...
Jul 01, 2009 | Acer Aspire 3000 Notebook
Gateway e4100 "no audio device"
Hi John,
The multimedia audio controller is the sound driver.
Create a folder on you're desktop.
Download this driver for the Gateway e4100 PC.(Scroll down to motherboard downloads, & scroll a bit more until you see the sound drivers).
http://support.gateway.com/support/drivers/search.asp?st=pn&param=2800471
There are 2 drivers listed. Read the description under each. One lists motherboard names. After downloading into the folder run the exe within the folder. Open device manager. Right click on the multimedia audio controller once & left click update driver.
Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away. Click the browse button & point windows to the uncompressed folder within the folder you stored the sound driver. Once high-lighted click ok. Windows should install the driver software & add the sounmax icon into you're control panel. It will also install an icon down by the clock.
Good Luck!
If you still have troubles let me know.
Mike
Jun 20, 2008 | Computers & Internet
Driver don´t work (MacOSX Leopard
Here are the steps that you need to take to fix your issue:
1. Uninstall the current Wacom driver via the Macintosh HD on your desktop--->go into the Applications folder and then the Pen Tablet folder and click on "remove tablet". Once you have done the removal you will want to run a "repair disk permissions on your Macintosh HD.
2. The repair disk permissions can be done via the utilities folder on your Mac HD. Go to "disk utility" and then run it. In that program select the Mac HD and choose "repair disk permissions".
3. After that is completed you will get a message that says permissions repair complete!
At this time you will want to reboot your computer.
4. After rebooting you will want to go and install the latest driver from Wacom's website, www.wacom.com The most current driver is 5.08-2 for the Graphire 3 tablet.
That should do it!
Paul
May 02, 2008 | Wacom Graphire4 Digital Pen
HP LaserJet 1020 Printer Logo
14 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
