Fan doesn't turn on - Computers & Internet
  • cvin May 31, 2008
    thank you
  • 65 Answers
Chances are you have a short in the motherboard or your power supply is bad. Geek squad can check your power supply...
Posted on May 28, 2008
When i start the car it makes a squeaking sound, also the fan doesn't come on it is suppose to come on when you start the car or turn on the ac the fan doesn't come on.
could be the clutch fan if your fan doesn't come on. also the belts could be to tight or the alternator belt. good luck.
Mar 23, 2013 | 2001 Hyundai Sonata
Fan light turns on but doesn't turn off with remote also fan doesn't go on with remote
Make shure your batteries are good in the remote. Also some remotes have little dip switchers inside the battery cover that are either on or off. They must be in the same position as the dip switches on the receiver in the top canopy of the ceiling fan or the remote & receiver won't talk to each other. Apart from that you will probably need to replace the remote control & receiver unit.
Dec 12, 2012 | Hampton Bay 52 In.Carriage House II in...
Why would the cooling fan not be working in a 2005 crown vic CVPI
Does it work when you turn the A/C on? The fan always kicks on with the A/C, if it doesn't look for a blown fuse. Or possibly a fan motor burnt up. If it works with the A/C but doesn't when the engine is too warm, it is probably the temperature sensor.
Feb 09, 2012 | 2005 Ford Crown Victoria
Tower fan doesn't turn on
see if the timer is set to the desired setting
Jul 20, 2011 | Haier FTP120W FAN TOWER
Car keeps over heating because fan doesn't turn on
Your car has electric fans and they are activated by a switch that is mounted in the bottom of the radiator. What you need to do is verify first that the fan motor is good. After that then you want to "jumper" the switch and see if the fan runs. Jumpering is when you disconnect the wire from the switch and use a piece of wire to connect the wires of the harness together as if the switch was "turned on"..If the fan works then the switch is probably bad, If it doesn't then I would look for the fan "relay"..
Jul 11, 2011 | 2000 Ford Focus
1995 chevy lumina sensor went out and fan wont turn
How did you determine that the sensor failed. Did the check engine light come on? When you say that the fan won't turn, do you mean that it won't turn on and run or that you can't physically turn it by hand. To determine this, disconnect the electrical connector to the fan and try to turn it by hand. It should turn easily. If it doesn't then it must be replaced. If it does then reconnect the electrical connector to the fan and try to operate it by disconnecting the temperature sensor lead and placing a jumper wire between the terminals of the harness. turn the AC control to AC/MAX and turn the ignition key to on. If the fan runs then the problem is the sensor. If it doesn't then check the fan control relay and any related fuses. WARNING : Use extreme caution when testing the fan circuit. Never attempt to turn the fan with the electrical connector in place. The fan can operate at any time even if the engine is off.
May 14, 2011 | 1995 Chevrolet Lumina
1993 CORVETTE AC PROBLEM
Are you fully charged though? If you don't have a full charge the clutch will not kick in.
Aug 18, 2009 | 1993 Chevrolet Corvette
A/C FAN NOT WORKING
I presume you are talking about the blower motor and not the cooling fan on the engine?
If you have checked the fuse then ensure there is power at the blower motor when switched on.
Jul 22, 2008 | 2005 Jeep Wrangler
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
